Detect shorted turns in motor windings...
Discussion in 'Electronic Repair' started by Tor Tveitane, Nov 7, 2004.
  1. Tor Tveitane
    Tor Tveitane Guest
    Can I use a LCR bridge in inductance mode to measure difference in
    inductance if I suspect one of the windings in an electrical motors to have
    shorted turns...?
    What is the preferred way to check for shorted turns within an inductor...?
    Thanks for clues
    Tpr
  2. CJT
    CJT Guest
    I don't know what's preferred, but one way might be to ring it like
    a flyback and look at the response.
  3. NSM
    NSM Guest
    | Hi,
    have
    | shorted turns...?
    Sure. Compare the ratio of inductance to resistance.
    inductor...?
    For shorted turns in a motor use a growler.
    N
  4. That was my thought/guess as well.
    Tom
  5. Tor Tveitane
    Tor Tveitane Guest
    Any urls and info to show how to setup this and to diagnose the response..?
    Tor
  6. NSM
    NSM Guest
    | "Tom MacIntyre" <> skrev i melding
    response..?
    http://repairfaq.ece.drexel.edu/REPAIR/F_appfaqi.html
    What sort of motor? What's shorted, field or rotor?
    N
  7. CJT
    CJT Guest
  8. N Cook
    N Cook Guest
    I've never used one but isn't a growler used for this purpose.
    electronic hints and repair briefs
    http://homepages.tcp.co.uk/~diverse
  9. Ross Herbert
    Ross Herbert Guest
  10. Yes, though it would be hard to justify the expense to fix one small
    motor.
    See, for example: http://www.sotcher.com/mre/520.html
    It's just the primary of a transformer connected to 60 Hz along with
    a hacksaw blade, so you could probably build one or improvise from
    something else.
    --- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
    Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
    +Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
    | Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
    Note: These links are hopefully temporary until we can sort out the excessive
    traffic on Repairfaq.org.
    Important: Anything sent to the email address in the message header is ignored.
    To contact me, please use the feedback form on the S.E.R FAQ Web sites.
  11. Jim Adney
    Jim Adney Guest
    Yes, but any electric motor shop, or automotive electric shop will
    have a growler and would charge only a very small fee to test an
    armature for you.
    Disassemble the motor and just take in the rotor, so that they don't
    have to do any significant work.
    If you bring it over here, it would take me less than 2 minutes to
    check it out. ;-)
  12. IF, it's a wound rotor motor. Most ac rotors are of the squirrel cage
    variety.
  13. Jim Adney
    Jim Adney Guest
    I was wondering about that. Wouldn't a squirrel cage motor still have
    the same magnetic properties? I'm not sure, but I'd bet that such a
    rotor would still pass the growler test, but it's hard to imagine a
    squirrel cage rotor with a short in it, which, I believe is what the
    OP asked about.
    Does anyone know if this happens?
  14. NSM
    NSM Guest
    | On Tue, 9 Nov 2004 16:41:01 -0500 "Charles Schuler"
    | >variety.
    | OP asked about.
    I don't know how to 'growl' a squirrel cage motor. I'd just fire it up and
    check the amps on each leg.
    NM
  15. James Sweet
    James Sweet Guest
    I've never even heard of a rotor failure on any type of induction motor,
    usually it's the starting switch, capacitor, or bearings that fail. The
    stator windings can burn out but it's rare.
  16. By definition, a squirrel cage rotor is all shorts. :)
  17. The only way a squirrel cage rotor could fail would be for one or more
    of the shorting bars to open. A quirrel cage rotor is based on all
    the bars being shorted at the end-plates.
  18. Jim Adney
    Jim Adney Guest
    Right, but so is a regular commutator rotor. The only difference, I
    think, is that the squirrel cage rotor is wound with much more rugged
    "wire."
  19. Nah. :) A commutator motor happens to be shorted but that is a byproduct
    of how it's wound, not a requirement. A squirrel cage rotor is a bunch
    of copper bars embedded just under the surface of a solid steel rotor
    running length-wise. They are shorted at the end plates. Since these
    are induction motors, they depend on the current flowing in the bars
    as the secondary of a transformer to provide the torque.
    For brush-type motors, current is applied to the rotor windings via the
    brushes. It's possible to build such a motor without "shorted" windings.
  20. Asimov
    Asimov Guest
    "Jim Adney" bravely wrote to "All" (11 Nov 04 20:57:04)
    --- on the heady topic of "Re: Detect shorted turns in motor windings..."
    JA> From: Jim Adney <>
    JA> Right, but so is a regular commutator rotor. The only difference, I
    JA> think, is that the squirrel cage rotor is wound with much more rugged
    JA> "wire."
    The squirrel cage rotor is really a rotating transformer with a very
    low resistance secondary. Any phase difference (slip) between the
    applied field and the transformed field generates very high currents
    in the range of 100's of amperes. To say the rotor is wound with much
    more rugged wire is really an understatement. It is this high current
    that causes a counter emf, applying a mechanical torque to the shaft,
    and results in the desired motor action.
    A*s*i*m*o*v
    .... Electrical engineers deal with current events.
