: Desoldering station
Wanted: Discussion in 'For Sale / Wanted' started by Axel87, Mar 12, 2013.
Thread Status:
Not open for further replies.
  1. Axel87
    Axel87
    23
    Aug 18, 2012
    Looking to get my hands on a Desoldering station. Working with mostly through-hole so I don't think a hot air is what I'd be looking for.
    A single sucker gun or gun w station.
    Not looking to spend alot, under 150?
    If it needs work, could be open to that as well.
    Hope someone out there has an extra lying around!
    Thanks!
  2. (*steve*)
    25,497
    2,838
    It might be worth telling us approximately where you are because we have members all over the world.
  3. Axel87
    Axel87
    23
    Aug 18, 2012
    Sorry- forgot that bit.
    Located in Grand Forks, ND. 58203.
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Heat board with regular iron, give board quick snap on table, solder flies out of the holes :) Or heat up with hot air, turn board over and do the same thing, the chip and solder will fly out :)
    Yep, these are cheap Asian copies but I have used these things for years, they work exceedingly WELL for the money...
    http://www.circuitspecialists.com/thsudest
  5. Axel87
    Axel87
    23
    Aug 18, 2012
    Interested in that station!
    Thanks for the link, probably get one soon. Seems like a fair price!
    Anyone else have experience with this unit? Hold up well and are efficient?
  6. (*steve*)
    25,497
    2,838
    I have a very similar looking SMD rework station.
    The soldering iron died after I had it turned up full for a while to de-solder something that was on a massive heatsink. But used for rational things it worked well. I can get replacement parts, but I have another temperature controlled iron that I'm using right now. (hint: get spare elements when you order one -- it's a lot cheaper than getting them afterwards)
  7. Mitchekj
    Mitchekj
    288
    Jan 24, 2010
    Thru-hole? I have never been let down by the beauty attached. Do I get laughed at sometimes? Maybe. But I find these are particularly well suited for cheaply made PCBs in which the annular rings are easily torn off by some of the more 'fancy' desoldering stations.
    $28 from McMaster... Solder Sucker
  8. Six_Shooter
    Six_Shooter
    98
    Nov 16, 2012
    Same thing I use, though I've paid less for my two solder suckers. (One for home and one for my portable tool box).
    Eventually I'd like to get a proper desoldering station though.
Thread Status:
