Designing a VCO
Discussion in 'Electronic Design' started by Mounir, Oct 24, 2005.
  1. Mounir
    Mounir Guest
    Hello everyone!!
    Well, Im doing a project which requires a VCO in my circuits, the proble
    is im not able to design the one i need (the VCO should oscillate betwee
    85MHz and up to 125MHz only, since these are the allowed free channels)
    can anyone suggest me a design? ty
    This message was sent using the sci.electronics.design web interface o
    www.Electronics-Related.com
  2. Jim Thompson
    Jim Thompson Guest
    Buy either an MC1648 VCO (sine wave) or MC1658 VCM (square wave), both
    designed by yours truly.
    ...Jim Thompson
  3. Guest
    Higher then 109 MHZ is international air navigation band ANYWHERE in
    the world.
    109-138 is the air band range. Sorry if your using high side
    injection.
    Steve Roberts
  4. Joerg
    Joerg Guest
    Hello Jim,
    Arrow doesn't carry those anymore and ON Semi draws a blank, too.
    But the 1648 now comes with a Porsche engine, MC100EL1648. It's a rocket
    at 1.1GHz and a surprisingly low supply current under 25mA. Did you
    design that one as well?
    Regards, Joerg
  5. DaveM
    DaveM Guest
    MiniCircuits (www.minicircuits.com) makes a line of VCO modules; their model
    POS-150 would fit exactly within your range.
    Freq Range 75-150 MHz
    Output level +9.5 dbm
    Tuning voltage 1-16 VDC
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in
    the address)
    Never take a laxative and a sleeping pill at the same time!!
  6. Jim Thompson
    Jim Thompson Guest
    It's my MC1648 schematic with a bias modification to match 100K TC,
    and processed on 100K.
    ...Jim Thompson
  7. 108-117.975 - Navigation
    118-136.975 - Communications
    So what if he is using high side? The device is still required to meet part
    15 spurious which should limit the range safely.
    Jim
  8. Joerg
    Joerg Guest
    Hello Jim,
    I guess legally you'd still be the father then because your DNA is in there.
    Regards, Joerg
  9. Jim Thompson
    Jim Thompson Guest
    Yes, I've spread a bit of it around ;-)
    ...Jim Thompson
  10. Is the original plain-jane variety still being produced?
    Jim
  11. Jim Thompson
    Jim Thompson Guest
    http://www.lansdale.com makes it. They still make quite a few of my
    '60's designs.
    ...Jim Thompson
  12. Mark
    Mark Guest
    look at Mini Circuits..
    Mark
  13. For these frequencies why not using a DDS and not a VCO/PLL ?
    Friendly,
    RObert
