Designing a high current (10A) voltage buffer
Discussion in 'Electronic Design' started by Michael, Jul 28, 2007.
  1. Michael
    Michael Guest
    Hey there - so my job doesn't allow me to do much in the way of analog
    design, so for fun last night I decided to design a high current
    voltage buffer. The idea is that it'd take a 0-10V input, and would
    output the same voltage, except with the ability to drive up to about
    10A. The design eventually evolved in my head into a PID controller
    using op amps driving a P FET. So I scribbled down some notes and
    passed out. This morning I drew it out, corrected a couple oversights,
    and chose some components. I have posted what I came up with here:
    http://s2.supload.com/free/High_Current_Voltage_Buffer.png/view/
    The op-amp choice was very arbitrary - I just wanted a rail to rail
    quad op-amp, and the OPA4234 was already in my schematic capture
    program's library. I chose the FET a slight bit more carefully - I
    wanted a low on resistance FET capable of dissipating a lot of power
    while also being able to handle a lot of current. I ended up with the
    IRF IRLR9343. It can't completely handle the specs I gave - but it can
    get fairly close.
    So - in this design R2, R3, R4, and R5 set the PID gains, with P = R2/
    R3, I = R2/R4, and D = R2/R5. I put in fairly arbitrary values for R2-
    R5 - giving initial gains of 0.5 for all three. This would obviously
    need tweaking based on the application. Also, the resistor between the
    op-amp and the gate of the FET was a pretty arbitrary value - I put it
    in there to protect the op-amp, though it'll also significantly slow
    down the circuit.
    So - can anybody spot any mistakes? I suspect there are at least a
    couple. Also - is there any way to do this on a unipolar supply? Any
    way to get rid of an op-amp? My only thought on getting rid of an op-
    amp was to make the summer into a combination summer/difference
    amplifier so that it'd sum the I and D terms while subtracting the -P
    term, but I couldn't find a way to make the math work out cleanly. Any
    other comments or suggestions?
    Thanks!
    -Michael
  2. John Larkin
    John Larkin Guest
    You won't need the derivative term, and you can combine the integral
    and proportional into one opamp by using a series r+c as the feedback
    element.
    Make the gate resistor 33 ohms maybe; it keeps the fet from doing RF
    oscillations on its own.
    John
  3. linnix
    linnix Guest
    Is your supply capable of 10A? Driving the gate of the FET wouldn't
    gain anything. The op amp is doing nothing at all. You can't boost
    current without L & C.
  4. Yes. The gate looks capacitive, so, if the MOSFET is
    following only slowly changing voltages and the circuit is
    stable, the gate current will always be small. And most
    opamps have enough current limit in their output stages to
    protect the opamp for quite a while. The only real need for
    a gate resistor might involve preventing high frequency (RF)
    oscillations in the MOSFET, by killing the Q. But something
    in the 10 to 100 ohms range usually works better for that.
    A ferrite bead over the source lead is also sometimes used,
    but it will probably saturate with 10 amps DC in this
    application.
    I haven't solved any equations, but it looks functional, if
    over complicated. It should be possible to merge all that
    gain network (5 opamps and all their resistor and capacitor
    input and feedback capacitors) into a single opamp.
    Sure, if the input stays between those rails, and there is
    enough voltage to drive the MOSFET. A single +12 rail
    should do it.
    How about 4?
    Draw a single opamp follower. Add a MOSFET current booster
    to it, an inverting booster, in this case. This extra
    inversion will require that you reverse the inputs on the
    opamp. Build it, and you will find that it is not stable,
    because the internal gain versus phase of the opamp that
    made the opamp follower stable did not take into account the
    additional gain and phase shift of the MOSFET inverter
    inside the feedback loop.
    You have to add some lead lag compensation to the feedback
    (and possibly to the input side) that approximates what you
    are doing with the PID construction, that lets you control
    the gain roll off and phase shift so that, at the frequency
    where the loop gain falls to 1, the phase shift does not
    approach or exceed 180 degrees, so that stable, negative
    feedback operation takes place. It can be done the one opamp.
    I don't want to hand you a finished answer, right away,
    because I think you are having too much fun thinking about
    this, right now.
  5. 1. The design looks owerweighted. The whole PID regulator can be done in one
    opamp unless you need to adjust the parameters independently.
    2. You have Q1 in common source mode. Thus the transconductance of Q1 is
    included into the loop gain. I don't like this idea because it is a variable
    parameter. I would use rather use bipolar Darlington as the emitter
    follower.
    Vladimir Vassilevsky
    DSP and Mixed Signal Consultant
    www.abvolt.com
  6. MooseFET
    MooseFET Guest
    The Power Supply Rejection Ratio will really suck. You only need one
    op-amp to do the whole thing. The differential section won't work.
    You don't need a -12V supply. You didn't do anything to control the
    gm of the MOSFET section. Your design suggests a 10uF capacitor that
    I suspect you will have trouble with. 25nA times 100K puts the offset
    voltage at 2.5V. You are putting an heavier load on Vin than you need
    to. Your feedback path runs through 3 350KHz op-amps forcing you to
    use a low gain crossover frequency. You didn't provide for an anti-
    windup circuit. The output pulses high at power up. The resistor
    feeding the gate of the MOSFET is too high. You didn't show any
    bypass capacitors.
    Other than this, its a great design.
  7. MooseFET
    MooseFET Guest
    Its easier to just add a small source resistor to the MOSFET. You
    would still get nearly the full swing but have a gm that is well
    enough controlled.
  8. Michael
    Michael Guest
    What is Q? I'm not familiar with that term.
    I had that suspicion - I always tend to use way more op-amps than are
    really needed.
    But the P term will initially dip below zero.
    An op-amp follower - as in a buffer? (ie
    http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/opampvar2.html)
    An inverting MOSFET current booster is what I drew, right? Or are you
    referencing something else?
    I don't follow what the feedback system would be in this case. Can you
    elaborate on that?
    Ah - lead/lag design - fun stuff. How do you implement a lead or lag
    controller with an op-amp? I've only done lead lag design with DSP
    systems - never analog.
    By the way John - I'm not sure if you realized this or not - but this
    is Michael - the robot guy. Good to see you!
    -Michael
  9. Michael
    Michael Guest
    Why skip the D? I mean, it doesn't hurt anything - when properly
    tuned, it only helps...
    On another note - something's been bothering me - would it be possible
    to make just a proportional controller? I feel like if I set the I and
    D gain terms to zero this thing would oscillate terribly, but looking
    back through my control systems textbook P controllers are shown to be
    stable, though they can have a steady state error.
    So - where'd you get 33 from? That was one of those values that I just
    didn't have a clue about...
    Thanks!
    -Michael
  10. Michael
    Michael Guest
    In my theoretical design - yes, the supply is infinite. I don't follow
    what you're saying about the op-amp not doing anything?
  11. Michael
    Michael Guest
  12. Quality factor of a resonant system. High Q implies sharper
    resonance and large stored energy, compared to losses per
    cycle. The gain and feedback capacitance from drain to gate
    can produce a resonant system that can self excite with some
    gate driver source impedances (oscillate).
    http://en.wikipedia.org/wiki/Q-factor
    (snip)
    No problem, if it helps you deal with all aspects of the
    problem, conceptually. But then you get down to the
    engineering aspect of merging all those features into a
    reasonable circuit.
    Under what situation?
    (snip)
    Yes. The simplest opamp amplifier. ~infinite current gain,
    voltage gain = 1.
    Your MOSFET amplifier is exactly what I am talking about.
    The simplest idea is to switch the opamp inputs and take the
    voltage feedback from the drain, instead of from the opamp
    output. But that will almost certainly turn out to be unstable
    Lead/lag refers to the phase shift of a given network. You
    also get a frequency response that comes along with it.
    I did not realize. Nice to be thinking with you again.
    The final feedback must, at DC have a gain of 1 from the
    MOSFET output back to the effective inverting input, just as
    it does with the simple 1 opamp follower (which has that
    gain at all frequencies, not only at DC).
    But the feedback network (that can include signals from both
    the opamp output and the MOSFET output) can have other gains
    and phase shifts at other frequencies.
    A very simple, though, perhaps sub optimal (not the highest
    frequency response) version would be a resistor from MOSFET
    output back to + and a capacitor from the opamp output back
    to +. This pair has a perfect gain of 1 at DC from the
    MOSFET output (since the capacitor has infinite impedance at
    DC). But above some frequency, where the capacitor
    impedance approaches the resistor resistance, the capacitor
    takes over as the effective feedback, and the MOSFET output
    no longer follows the input, but the opamp is kept in a
    stable feedback situation.
    There are many variations on this theme that also include
    components connected to ground to make the feedback network
    some sort of voltage divider, and series RC loads on the
    output to narrow the range of gains and phase shifts
    possible as the load impedance changes.
    If the actual load is fixed, things get a lot simpler. If
    the load can vary anywhere between infinity and 1 ohm, you
    have a lot more cases to deal with. This is one reason why
    a big follower booster is often used (emitter or source
    follower configuration). That configuration varies in its
    gain and phase shift a lot less as the load impedance varies.
  13. Michael
    Michael Guest
    I was assuming that the op-amp and the fet were on separate 12V
    supplies, if that is what you were referring to. Sorry that that
    wasn't made clear.
    I found one PID controller implemented on a single op-amp, but it
    didn't give a nice way of tuning - if you changed any component you'd
    change all three gain terms. Can you suggest a better method that
    allows individual tuning of gains?
    I think I do with how the circuit is currently set up. The P section
    will be generating a negative voltage. Unless I completely change the
    circuit - I believe it is necessary.
    How would you suggest changing the circuit so that it is controlled?
    What's so hard about sourcing a 10µF cap? I don't follow. I didn't
    want the resistor to be any larger (being that the input impedance of
    the op-amp is in the Mega ohm range) - hence the large cap. I suppose
    I could compensate for that when setting the gain - but that's a
    little ugly.
    Can you elaborate on this? I don't know what you're referring to.
    I agree completely. I'll change R6 through R9 to 100Ks.
    Like I said - the op-amp choice was arbitrary. I am really quite
    confused when it comes to choosing op-amps - when is fast too fast? I
    always hear warnings that really fast op-amps can cause really bad
    oscillations.
    I am not familiar with this term. Can you elaborate on it?
    I'm aware of that one. I don't agree that it is absolutely a bad thing
    - I mean in some applications the output being low on startup could
    cause failures. How would one change the circuit so that you could
    control the initial Vout?
    Another arbitrary value choice. How does one choose this value? I'm
    thinking that you would look at the gate capacitance and then choose a
    resistor such that the time constant (RC) had a period of half of the
    frequency you want the circuit to run at. You would also have to
    verify that that won't be asking the op-amp to drive too much current.
    I guess I always feel those are just assumed :)
    Hey now, I am stuck just doing embedded design at work - I'm rusty on
    all this analog stuff :)
    Thanks, I really appreciate it.
    -Michael
  14. Michael
    Michael Guest
    wasn't made clear.
    little ugly.
    oscillations.
    -Michael
  15. I have to disagree. The voltage gain of this stage should be more or less
    constant regardless of load. That can be achieved by local voltage feedback,
    not by current feedback. Something like R or RC between drain and gate will
    probably do.
    Actually, it is fun to design RR output stages because you have to optimize
    several different things.
    www.abvolt.com
  16. John Larkin
    John Larkin Guest
    It can be a huge noise amplifier, and gets quirky in a lot of
    situations.
    Sure. But the opamp isn't ideal, and its gain will start to droop at
    some frequency, so it's never going to be pure proportional. And a lot
    depends on the load... if it's a pure resistor as shown, good, but any
    load capacitance complicates life, and the fet itself has capacitance.
    So the proportional gain may have to be very low to keep the loop
    stable, so then you's need some integral to get accuracy.
    This ain't simple. Keep in mind that the transcondance of the fet will
    vary with current, so the loop dymamics aren't fixed. The safe thing
    to do is to make a *slow* P+I controller, slow as in low KHz loop
    bandwidth, if you can tolerate that.
    Seems to keep most mosfets from becoming RF oscillators. Bigger values
    work too, but may slow down the fet gain and complicate the loop even
    more.
    John
  17. John Larkin
    John Larkin Guest
    I didn't follow that either!
    John
  18. D from BC
    D from BC Guest
    Maybe it's just me..but don't P Fets suck?.. :p
    I'm no pro but on a few occasions have compared N Fet specs and prices
    and P Fet specs and prices.. I currently have the belief that N power
    Fets generally outperform P power FETs.
    Hope you can keep that P Fet junction temperature within safe limits
    with 10A max.
    D from BC
  19. I think N fets make better use of the silicon. In other
    words, for a given chip size, you get a higher performance
    fet if it is N-channel than if it is P-channel. Higher
    performance is defined as
    1/(gate capacitance * channel resistance) or some such.
  20. MooseFET
    MooseFET Guest
    This is because holes are so hard to move. Electrons are nice round
    little balls but holes have sharp corners all over the place.
    The very nice thing about a P-MOSFET is the fact that you can switch
    the positive rail with a signal less than that. They make very nice
    "you hooked the battery up wrong" diodes and power switches for
    circuit sections as a result.
    10A * 12V = 120W
    If you buy a good one in a TO-218, you can do this with boiling water
    cooling. No L-N2 is needed.
    If you add a small balasting resistance, you can parallel about 10
    MOSFETs to get a more reasonable power in each. I suggest the
    balasting resistor because at low currents, the Tc is in the "this
    thing runs away" direction.
