Designing a 4th order 3 way crossover
Discussion in 'General Electronics Discussion' started by CommanderLake, May 20, 2015.
  1. CommanderLake
    CommanderLake
    199
    6
    Oct 2, 2012
    I'm designing a 4th order 3 way crossover for some 3 way speakers consisting of the following Dayton Audio speakers:
    ND25TA-4
    RS52AN-8
    RS225-8
    I know very well a speaker is not just a resistor and inductor but thats as close as I can get with my favourite circuit simulator, enable European resistors in the options menu...: Heres the circuit
    The problem is, as you can see on the graph on the right, the source current draw at 1 volt makes the minimum impedance of the mid driver bandpass section about 3.33 ohm's, I'm afraid that might be too low for the Pioneer VSX-924 I plan on using.
    Is there an ideal solution to this?
