Design question on microcontroller and TIP122
Discussion in 'Microcontrollers, Programming and IoT' started by dashy1981, Jun 19, 2013.
  1. dashy1981
    dashy1981
    46
    Jun 19, 2013
    Hi Guyz,
    I need design help on a switching circuit. Its going to switch 4V, 250 mA load.
    I am considering NPN TIP122 as switch.TIP122 will be controlled through 89c2051.
    I have a doubt regarding feasibility of sourcing TIP from 8051 pin. According to my understanding of datasheet it can sink 20mA of current, sourcing should be much lesser I guess. But in this application I need to source current to base of TIP.
    So I think I can not directly connect base to port pin... or I am wrong?
    I work more on SW, so if this seems a stupid question please ignore.:)
    Cheers
    dashy
  2. (*steve*)
    25,477
    2,820
    If I were you, I would be using the 8051 to turn on and off a mosfet.
    This page describes how it's done.
  3. BobK
    7,682
    1,687
    A TIP122 is way overkill for a 250mA. You could use a 2N2222, it can switch up to 800mA. Assuming a gain of 100, you would need only 2.5mA to the base. I don't know what an 8051 can source, but it seems likely it could do that much.
    (or a MOSFET as Steve suggested, while I was typing in my reply)
  4. dashy1981
    dashy1981
    46
    Jun 19, 2013
    I'm not an expert on this but I'm very clear on my requirement. Its should be cheapest.
    So going through price list this one was what I found cheaper than mosfets.
  5. (*steve*)
    25,477
    2,820
    I beg to differ. You have only just mentioned it.
  6. dashy1981
    dashy1981
    46
    Jun 19, 2013
    :) Agree. I thought that need not mention, since my V/I reqs I had mentioned. but yes that not explicitly mentioned.
  7. dashy1981
    dashy1981
    46
    Jun 19, 2013
    I checked 2N2222, that looks prettier and cheaper than TIP. But I am going to use it to cut off/On a power supply to a load(4V, 250mA). So do I need to consider power dissipation by the transistor. i mean will 2N222 be able to sustain heat ?
    BTW how do I calculate this myself ?
  8. BobK
    7,682
    1,687
    At mouser.com:
    tip122 $.050
    pn2222 $0.06
    NTD4963N (mosfet 44A, 13.9mOhm) $0.19 (this is a great bargain)
    So, no, the tip122 is not the cheapest solution.
    And if you want to go surface mount, there is:
    NX3008NBK,215 (mofset, SMD, 400mA, 1.4Ohm) 0.05
  9. BobK
    7,682
    1,687
    A TO92 transistor like the PN2222 can dissapate 1/2W. At 250mA and say 0.2V when saturated, it should be dissapating only 1/20th of a watt. No problem at all.
  10. (*steve*)
    25,477
    2,820
    Remember to add the price of the series resistor Bob!
  11. BobK
    7,682
    1,687
    0, because they come out of my parts cabinet.
  12. dashy1981
    dashy1981
    46
    Jun 19, 2013
    As I mentioned that application will swith on or off the power supply to the load(4v,250mA). Since the transistor will be connected in between do I need to increase the voltage of power supply to counter fo the drop due to transistor? If yes how do i find out by how much to apply. Question is imp because the my load is costly n i sensitive one.
  13. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    A TIP122 will drop about a volt, because it's a Darlington transistor. Therefore you can't use it in your application.
    A general purpose NPN transistor such as 2N2222 will drop something like 0.3V at 250 mA load current.
    If you use a MOSFET with a low Rds(on) you do not need to worry about voltage drop across the switching element. You do have to worry about the gate drive voltage though. Standard MOSFETs need a few volts to turn them ON properly. You didn't say what voltage your micro is running at.
    If you need low gate drive voltage, here's a good option for you: http://www.digikey.com/product-detail/en/SSM3K123TU(T5L,T)/SSM3K123TU(T5LT)CT-ND/2257798 USD 0.49 @1x
    Rds(on) is [email protected]=2.5V and [email protected]=4V.
    So even if you only have 2.5V to drive the gate, its resistance of 0.032 ohms will only drop 0.008V. That's 0.2% of your total voltage.
    This is the reason why everyone has been telling you to use MOSFETs in this application.
  14. dashy1981
    dashy1981
    46
    Jun 19, 2013
    Hi Kris, I am using an 8051 based MC at 5V. Even though the TIP will drop around 1V it should be fine I guess. Reason being TIP will be switching on/off a seperate power supply which is connected to my load. So if my load needs 4V,250mA then I can always increase power to 5V(its a high quality agilent variable power supply(0-30V,5A)).
    During off period my load will be protected anyway. And when TIP is on then 1V drop by TIP + 4V by load => I can make my power supply set to 5V.
    Will it be ok ... or I'll have any side effects ?
  15. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    It depends on how the two supplies are connected together. Are they completely independent?
    A schematic would explain a great deal. Show the MCU's power supply, the MCU, the other power supply, the load, and the position where you want to insert the semiconductor to control the load.
    I don't think it's good reasoning to say that you can tolerate a 1V drop because you can increase the other power supply voltage if necessary. That 1V represents wasted power, which is converted into heat. Admittedly, 0.25W is not a huge amount of power, but it is still wasted. Also, the transistor requires a continuous base current to keep it turned ON, and this is also wasted power.
    I do not see ANY reason to prefer a TIP122 over a small MOSFET.
    Consider the relative advantages and disadvantages of the TIP122 and a nice MOSFET.
    TIP122
    NPN Darlington
    Collector-emitter voltage drop ~1V at 250 mA
    Continuous base current ~1 mA required to ensure saturation
    USD 0.60 approx (Digikey, 1-off price)
    TO-220 package
    Power dissipation ~0.3W
    ON Semiconductor NTD4906N
    http://www.digikey.com/product-detail/en/NTD4906N-35G/NTD4906N-35GOS-ND/2194521
    Drain-source voltage drop 0.002V at 250 mA (Rds(on) 0.008R at Vgs=4.5V)
    No continuous gate required to ensure saturation
    USD 0.57 (Digikey, 1-off price)
    IPAK package, significantly smaller than TO-220
    Power dissipation <0.001W
    The only disadvantage I see with the MOSFET is that anti-static handling procedures are required.
  16. dashy1981
    dashy1981
    46
    Jun 19, 2013
    Here is the basic schematic.
    V1: My power supply which needs to be switched on/off.
    R2: is my load.
    Pls ignore name of Xistor. It will either be TIP or any other part as suggested by experts here.
    One of 8051 pin will be driving it.
  17. dashy1981
    dashy1981
    46
    Jun 19, 2013
    Updated with some more details... Sorry am not an expert... pls tolerate
  18. dashy1981
    dashy1981
    46
    Jun 19, 2013
    fgt to add schematic..:eek:
  19. BobK
    7,682
    1,687
    That is not the way to use an NPN transistor as a switch. The load should be between the + voltage and collector of the transitor, and the emitter should be connected to ground.
  20. (*steve*)
    25,477
    2,820
    And why are you so resistant to using the correct device for the job?
