Design for LED Color Organ
Discussion in 'Electronic Design' started by LightBoy, Mar 10, 2005.
  1. LightBoy
    LightBoy Guest
    Greetings to all -
    I am designing a device that uses 7 modules of colored LED's that will
    be used for a specific purpose for a client. As part of that design, my
    client wants to be able to modulate these 7 modules with sound - voice,
    music, etc. (Either by microphone or low level input from a music
    source).
    I have found several schematics on the Internet labeled as "color
    organs" but most are only one or two channels - and virtually all use
    SCR's to modulate Line Voltage to control incandescent lamps. Does
    anyone have - or can anyone point me to where I can find at least a 4
    channel schematic - that could be adapted to each channel controlling a
    cluster of 6 LED's?
    I would be very grateful for any information anyone here could supply.
    Very best regards.......
    Don H
  2. Rob Gaddi
    Rob Gaddi Guest
    Modulate is a very vague word in this context. More specific
    description of the desired relationship between sound and each light
    will lead to more useful answers.
  3. LightBoy
    LightBoy Guest
    Thank you for your response. I will try to clarify. By "modulate" I
    mean the intensity of illumination of each 6 LED module would vary in
    sync with the volume level of the music - within each specified
    bandwidth of any channel's frequency. As is Low - Medium and High
    frequency bands. Is that more helpful?
    Thanks!
  4. Rich Grise
    Rich Grise Guest
    Just make some bandpass filters, rectify and filter their outputs, and
    use the voltages to control the LED power supplies.
    Good Luck!
    Rich
  5. Luhan Monat
    Luhan Monat Guest
    Look up Color Organ on my site listed below. It should be able to drive
    some LED's in place of the 110 volt solid-state relays. This unit has 6
    channels and does everything in software. The outputs are proportional
    to the signal level from six software filters.
  6. LightBoy
    LightBoy Guest
    Thank You for your reply! You have a GREAT looking site - and have done
    some really neat stuff!
    It may be I will use something similar to your design - but I was
    hoping to find something without going to a PIC design. But what you
    have created certainly intrigues me. A PIC programmer I am not, but I
    have a good friend who is.
    Thank you again for showing me a really neat design!
    Blessings!
    Don H
  7. LightBoy
    LightBoy Guest
    Thanks, Rich,
    I guess I was hoping to find something "ready made" and not have to
    experiment too much. Like not having to "re-invent the wheel." A
    previous reply by Luhan Monat (above) intrigues me - but I will look
    into your suggestion also.
    Many thanks for taking the time to reply and for your kind help ....
    Don H
  8. Paul Mathews
    Paul Mathews Guest
    National Semi has out a brand new chip designed to drive LEDs in a
    'color organ' manner. They're featuring it on their website, so it
    should be easy to find, although they don't use the 'color organ'
    phrase.
    Paul Mathews
  9. LightBoy
    LightBoy Guest
    Thanks, Paul,
    I'll go to their site to see if I can find it!
    Don H
  10. Kryten
    Kryten Guest
    Sounds much like a graphic equaliser display.
    I think I saw one which used an LM 3914/3915/3916 bar-chart driver to do one
    vertical bar which was then rapidly multiplexed through 10 or so spectral
    channels. This allowed it to drive a 10x10 matrix of LEDs.
  11. LightBoy
    LightBoy Guest
    Found it, Paul.
    It looks like the perfect solution. However, need to find a distributor
    who stocks it. Minimum order is 1000 until - at 90 cents a copy.
    Sheesh! So far can't find it in stock anyplace - maybe its too new yet.
    I will keep trying.
    Thanks again for the info!
    Don H
  12. LightBoy
    LightBoy Guest
    Thanks, Kryten,
    Interesting concept. I will check into this, also.
    Thanks for taking the time to respond.
    Gratefully,
    Don H
  13. Paul Mathews
    Paul Mathews Guest
    Ask a Nat'l rep to get you a sample. Ask nicely.
    Paul Mathews
  14. LightBoy
    LightBoy Guest
    Thanks, Paul,
    I have done that. I will see if they follow through.
    Don H.
