Design Flow: PCI or any other high-speed PC interface ?
Discussion in 'Electronic Design' started by valentin tihomirov, Feb 3, 2004.
  1. I would like to accelerate a data conversion task. We just send a stream
    of data to converter that produses a response stream. Actually, this
    converter is an emulator of a system we are going to simulate efficiently
    accelerating simulation task. As the goal is a number of simulations per
    time unit, the high performance channels are needed to communicate between
    application running on PC and emulator running on FPGA. The data conversion
    (encription, compression) should be a known and well-understood toipc; thus,
    I would like to see any good reference designs.
    As, I do not have any experiance in high-speed I/O, I would like to
    discover existing and popular high speed interfaces (DRIVERS, tools,
    examples, defign flows, methodologies, cores, etc.). Can anybody offer an
    Internet resource or an exellent book describing the topic? How many time
    would it take to built a simplest prototype in man-hours (100, 1000,
    million)? How costly will it be?
    Many thanks.
  2. A million oughta cover it. ;-)
    The various FPGA manufacturers have PCI cores, and such, for their
    products, but I've found them expensive in terms of up-front $$ and
    FPGA space. I decided to go with a PLX PCI-9054 (kinda long in the
    tooth now) as a PCI bridge. Drivers were readily available for it.
    See: http://www.plxtech.com/ You'll have to register to get the
    detailed specs (why, I haven't a clue).
    For more general information, try:
    http://www.opencores.org/ <== "open hardware" cores
    http://www.optimagic.com/ <== programmable logic jump station
  3. MM
    MM Guest
    Valentin,
    You need to be more specific in terms of what speeds you want to achieve,
    whether the rate has to be sustained, what kind of compression/encryption,
    etc... ?
    /Mikhail
  4. I'm trying to be very specific telling that the target application is
    simulations accelerator. The higher speed the better. As converter will be
    running on FPGA, this limits number of vectors per second that can be
    simulated to about 200MHz. Hence, the desired bandwidth is
    number_of_vectors_per_second * vector_width gives about 100Mbps..10Gbps (for
    both channels). Channels should not be symmetric (input can be faster than
    output or vice versa). I just want to discover existing PC-interfacing
    solutions, make a broader view in the field.
    Rather than doing conversion task in SW it is often more desirable to use a
    task specific HW. All kinds of FPGA-based accelerators are becoming more and
    more popular. I've even seen about universal FPGA-accelerators. Data
    converter is a simplest accelerator; its communication scheme includes only
    one input and one output stream. The simulator I would like to implement
    belogns to data conversion class as well. I have mentioned
    compression/encription asking for typical reference design of data
    converter. Thanks.
  5. MM
    MM Guest
    If you want your emulator to be pluggable into a standard PC, then the most
    obvious choice for the interface is PCI. With standard 32 bit 33 MHz PCI you
    can theoretically achieve 132 MByte/s. In practice I have achieved over 100
    MByte/s. If this is not enough you can go to 64 bit / 66 MHz PCI, which is
    pretty common nowadays too. To achieve high speeds on PCI bus your emulator
    would have to be a bus master for both reads and writes. The next step in
    performance is PCI-X, but I don't think it is wide spread among PC
    motherboards...
    Another way is to make your card look like a memory module. I think this
    approach was discussed here in the past. This seems like an interesting
    idea, but personally I prefer staying with standard interfaces.
    Then there are all kinds of fast serial buses, but if I were you I wouldn't
    go there for this application.
    /Mikhail
  6. Uwe Bonnes
    Uwe Bonnes Guest
    : I would like to accelerate a data conversion task. We just send a stream
    : of data to converter that produses a response stream. Actually, this
    : converter is an emulator of a system we are going to simulate efficiently
    : accelerating simulation task. As the goal is a number of simulations per
    : time unit, the high performance channels are needed to communicate between
    : application running on PC and emulator running on FPGA. The data conversion
    : (encription, compression) should be a known and well-understood toipc; thus,
    : I would like to see any good reference designs.
    : As, I do not have any experiance in high-speed I/O, I would like to
    : discover existing and popular high speed interfaces (DRIVERS, tools,
    : examples, defign flows, methodologies, cores, etc.). Can anybody offer an
    : Internet resource or an exellent book describing the topic? How many time
    : would it take to built a simplest prototype in man-hours (100, 1000,
    : million)? How costly will it be?
    If you only need to send data between some peripheral and the PC and latency
    isn't an issue, think about using a USB2 link, like the usrp Software radio
    peripheral (http://comsec.com/wiki?UsrpProtoIntro) does. About 32 MByte/sec
    were reached with unidirectional flow, 16 MByte in each direction
    bidirectional and a complete chain is provided.
    That way, you don't need to design an PCI adapter and can easily plug into
    any modern PC without opening it.
    Bye
  7. Thank you, Mihail. I'm aware about these opportunities and would like to
    know more. Looking for overviews, tools and step-by-step methodologies.
  8. Mac
    Mac Guest
    10 Gbps is pretty fast. The only way to get data in or out of a PC at that
    speed is to use the memory bus.
    Typical PCI is a little over 1 Gbps (theoretical). If you go 64-bit 66
    MHz PCI, that is only 4 times faster at 4 Gbps. Maybe PCI-X is fast
    enough for you. If you are using an FPGA, why don't you see if the FPGA
    vendor can fix you up with a 133 MHz PCI-X core?
    Good luck!
    Mac
  9. Consider 100/1000 Ethernet.
    -- Mike Treseler
