design a driver for DFB laser
Discussion in 'Microcontrollers, Programming and IoT' started by sajjad23573, Jul 19, 2019.
  1. sajjad23573
    sajjad23573
    Jul 19, 2019
    Hello
    I want to design a drive for a DFB laser transmitter.
    I want guidance for circuit design.
    And whether you have micro-code source code?
  2. Harald Kapp
    9,538
    1,967
    Look up "DFB laser driver" in your favorite search engine. The search will turn up lots of driver ics from different manufacturers that are suitable for DFB lasers. The chips usually come with datasheets containing application notes or separate application notes to support design of a complete circuit.
    For which processor? For which purpose?
    We have all kinds of source code for different processors, none of which may be what you are looking for. Please be more specific.
  3. sajjad23573
    sajjad23573
    Jul 19, 2019
    Tanks a lot for your quick response.
    i want to design a drive for laser with 1654 nm wavelength. i think i should do this by ARM micro controller or even DSP.
  4. Harald Kapp
    9,538
    1,967
    What exactly do you mean when you use the name "laser driver"?
    There is much more to a laser driver than a typical microcontroller can perform. You can use the microcontroller to create the modulating signal, but the modulation, control of laser diode current, temperature compensation etc. requires dedictaed electronics, fortunately today available in a single chip,
Similar Threads
Loading...
