Dented oven
Discussion in 'Electronic Design' started by [email protected], Aug 8, 2013.
  1. Guest
    Hi everyone,
    I just bought a brand new oven which was to have only a minor scratch on the handle. It's a Ariston OS99, which normally retails for NZ$2770, but I got it for NZ$995, because of the cosmetic flaw. But when I got it there was also a dent on the side of it. What I want to know is, could there be a issue with, i.e. insulation being squashed? Peaking through the holes in the outer casing, there doesn't seem to be electronic bits in that area, just insulation. I don't want to burn my house down because of improper insulation (it's one of those pyrolytic self-cleaning ovens that cleans at 500 degrees Celsius.
    Regards.
    Amanda
  2. Phil Hobbs
    Phil Hobbs Guest
    This isn't really a sci.electronics.design question, so I've
    cross-posted to sci.electronics.repair and set followups there. If it
    isn't on-topic over there, they'll be able to help, anyway.
    How big is the dent?
    Cheers
    Phil Hobbs
    Dr Philip C D Hobbs
    Principal Consultant
    ElectroOptical Innovations LLC
    Optics, Electro-optics, Photonics, Analog Electronics
    160 North State Road #203
    Briarcliff Manor NY 10510 USA
    +1 845 480 2058
    hobbs at electrooptical dot net
    http://electrooptical.net
  3. Guest
    Thanks Phil. And sorry, I'm new to this side of the groups.
    The dent is about 3/4 inch deep and about a quarter of the size of the sideof the oven. I'll try to post a picture to the other group.
  4. Jasen Betts
    Jasen Betts Guest
    Assuming it's fibre insulation and will recover if the dent is fixed
    call one of those "paintless dent repair" services.
    Their equipment is portable, so they can come to you.
  5. Neon John
    Neon John Guest
    Why don't you drop by your friendly local body shop and have them work
    the dent out? They specialized (at least some do) in getting out
    dents like that. Several techniques - heat gun and ice, working with
    a ball-ended tool from behind, induction heating, etc - can be used. I
    wouldn't think it would cost over $50.
    John
    John DeArmond
    http://www.neon-john.com
    http://www.fluxeon.com
    Tellico Plains, Occupied TN
    See website for email address
