Hmm, I could imagine the amalgam to act as a crystal detector, like in
the early radios in the 1920's. But what would act as ear phone, and
what as resonance circuit?
As noted in other responses, a resonant circuit is not mandatory,
especially for strong local AM stations. I suspect anyone who has
ever built a simple crystal radio (diode or traditional) in an urban
area has noted that one strong local station seems to dominate the
whole band, regardless of where tuned.
Likewise, there are electromechanical transduction processes that
work on biological tissue. The ones I have experimented with work
at higher voltages (several volts RMS), but that was to produce a
sound that was audible in free air. (This was a signal generator
with a paper clip on the hot lead. If you brushed your fingertip
on the clip in *just* the right way, you could hear the oscillator
frequency. Don't recall how the ground was connected.)
And of course the best example of a bio-electro-mechnical
transducer is an outer hair cell from the inner ear. These
guys have on the order of 100 mV across them, and when
the stereocilia ("hairs") at one end are moved by vibration,
they modulate conductance channels and the cell conducts
current at the vibration frequency. That part of the system
is of course going from mechanical to electrical. But in
response to the changing potential across the cell, it changes
its length and actually ends up boosting the mechanical
input signal. As far as I know, there has been no systematic
survey of other tissues to see if they have this
electrical-to-mechanical transduction property, unrelated
to their normal function.
So *in theory* there could be a transduction system.
My question was related to the signal level that could
be present in the first place, given what I supposed
is the Faraday shielding of the conductive tissue of
the head and mouth. I think there must be a way to
compute this, since the same issue would be involved
in (for example) using conductive foams and coatings
on electronic apparatus to get EMC compliance.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
