Demonstrating SEPIC capacitor overvoltage?
Discussion in 'General Electronics Discussion' started by eem2am, Apr 7, 2013.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
    Hello,
    Please assist in measuring short term overvoltages on my SEPIC capacitor......
    SEPIC capacitor is 22uF, X7R, 1812, 16V
    I have done a SEPIC converter.
    Max output power = 5W.
    Input voltage = 5 to 8.5V
    Output voltage = 5V or 40V (depending on luminaire)
    Switching frequency = 40KHz to 110KHz
    Constant off time control
    The SEPIC coupled inductor is coilcraft MSD1583-473
    http://www.coilcraft.com/pdf_viewer/...re:msd1583.pdf
    When i looked for overvoltages across the sepic capacitor on the Scope (200MHz bandwidth scope) , i merely placed the scope probe across the SEPIC capacitor.
    However, the scope probe ground will have an associated capacitance to the ground, and so i fear that i may have unwittingly filtered any overvoltage spikes away?
    -Must i use a differential probe to look for the overvoltages on the sepic capacitor?
    I am wondering if there will be overvoltages at start up, due to the ringing with the leakage inductance of the coupled SEPIC inductor?
    Also, as the FET switches, i fear that there may be overvoltages on the SEPIC capacitor at these intervals also?
    Do i need the differential probe?, and what bandwidth Diff probe must i purchase?
