Demagnetizer Current Draw?
Discussion in 'General Electronics Discussion' started by johnkobe, Apr 1, 2013.
  1. johnkobe
    johnkobe
    Apr 1, 2013
    Hello All,
    I have a ~ 30 year old demagneizer in very good condition (don't know if it was ever used) that consists of 4 coils. The coils have 230V written on them and it appears they are wired for single phase power. My question is, if I want to know the total current draw, do I measure the resistance of each coil and use the equation, current = volts/resistance, then add up the calculated currents?
    Photo attached.
    Thanks!
    John
  2. (*steve*)
    25,497
    2,838
    No, you really need to know the inductance of them (and from that determine the magnitude of the reactance, and then the current). Then, if they're in parallel, add the currents.
    Be aware that the current will not be in phase with the voltage, so you can't multiply the voltage and current to get power.
  3. johnkobe
    johnkobe
    Apr 1, 2013
    Thanks Steve,
    Now all I need to figure out is how to "know the inductance of them (and from that determine the magnitude of the reactance, and then the current)." using only my multimeter.
  4. (*steve*)
    25,497
    2,838
    If your meter can measure inductance (and gives you readings that are not right at the bottom of the scale) then you're OK.
    Otherwise you need to find someone with the equipment to measure it.
    The reactance is 2*pi*f*L where f is 50 or 60, and L is the inductance you measure in Henries.
    The result of this (Z) can be used to calculate the RMS current which will be:
    I = V/Z; where V is 110, 220, 240, etc, and Z is as calculated above.
    Since the input is sinusoidal, if you want the peak current then you will need to multiply I by the square root of 2.
    Simple :)
