T
Tim Shoppa
When I open the catalogs I see both "Y" and "Delta" arrangements
for three-terminal TVS's. But I'm not entirely clear on where each
arrangement is most appropriate. My random thoughts:
The Y has two suppresors in series between any two terminals. Putting
them in series, I suppose, reduces capacitance, which may be important
at higher frequencies. But it also seems to double the impedance to
shunt a HV pulse.
The Delta seems to be better
at clipping lower voltages because you don't have to put two elements
in series.
But there must be something I'm missing here as to which is best used where.
My current application is rather low voltage (3.3V differential pair) at
moderate rates (a few Mbits) and it seems that the Delta configuration is
the best match.
Tim.
shunt a HV pulse.
in series.
the best match.
Tim.
