Dell
Discussion in 'Electronic Repair' started by GregS, Apr 28, 2009.
  1. GregS
    GregS Guest
    Got a Dell computer with something called a 110 Twin Alert.
    This little board on the top of the chassis is shutting down the power
    supply. I thought it might have been some kind of temperature
    alert gone bad. Got Got some power circuitry with a beeper.
    greg
  2. Franc Zabkar
    Franc Zabkar Guest
    Could it be this warning device with a 110dBa sounder and a low
    wattage speaker?
    http://www.pyronix.com/pdf/Data0305 TwinA.pdf
    The pinouts are:
    Symbol Description
    - 0V
    + 12V
    BA Siren Trigger
    SPK Speaker
    T Tamper
    T Tamper
    I can't see how it would be responsible for shutting down your power
    supply, though.
    - Franc Zabkar
  3. GregS
    GregS Guest
    Thats was interesting.
    I will post a picture later.
    greg
  4. GregS
    GregS Guest
    So here is a picture. I think its just a temp warning beeper that went bad and shorting out
    supply. Weird.
    http://zekfrivolous.com/misc/twinalert.JPG
    greg
  5. Franc Zabkar
    Franc Zabkar Guest
    It looks like the Pyronix device is something completely different.
    How do both trademarks coexist ???
    Here is a PC Power & Cooling alarm that is similar to yours.
    110 Alert Heat Alarm:
    http://www.pcpower.com/accessories/110-alert-heat-alarm.html
    It is set to go off when the temperature reaches 110 deg F. It doesn't
    appear to do anything other than alert the user, though.
    OTOH your device appears to shut down the PSU. You can see the
    thermistor below the second M in the LM339M quad comparator. Could
    that be a crowbar SCR across the +12V or +5V input? What are the two
    large parts at the RHS of the PCB?
    The only useful reference I can find to TwinAlert with Google is this
    one:
    http://www.kaldata.com/forums/index.php?showtopic=26035&st=30
    This is a Google translation:
    Sensory devices for heat
    Thus, this problem could be avoided entirely by using the company's
    110 Twinalert PC Power and Cooling Systems. Twinalert represents 110
    bus to the size of a credit card that is connected to the plug such as
    power flopito. When the temperature in the PC-it reaches 43 degrees,
    the device starts to squeak, creating annoying noise, and in 47
    degrees just excludes computer. It cost under $ 50 ...
    - Franc Zabkar
  6. Eeyore
    Eeyore Guest
    LM339 is a quad comparator. The board is also legended 'power and cooling'. I'd guess it
    monitors temp and several supplies.
    Graham
  7. Bob Larter
    Bob Larter Guest
    It looks like it's monitoring the temperature (there's a thermistor on
    the bottom right of the PCB). I notice that it has a local regulator,
    which I'd be guessing is a 7805 that's shorted out.
  8. Franc Zabkar
    Franc Zabkar Guest
    The pinout for a 7805, from top to bottom, is "In Gnd Out". This
    doesn't fit with the "+12V Gnd Gnd +5V" pinout of a drive connector.
    In any case why would you need a local +5V regulator when the incoming
    supply already provides +5V? If for some reason you did need a +5V
    regulator, then wouldn't a 78L05 be adequate for this circuit?
    - Franc Zabkar
  9. Eeyore
    Eeyore Guest
    That heatinked device seems rather odd, not least the way it's mounted with
    bent leads.
    Graham
  10. Bob Larter
    Bob Larter Guest
    <looks again>
    Yeah, you're right about it not being a 78xx reg. I must've been a bit
    slydexic when I first looked at it.
