Dell (sony) trinitron P991 monitor not "starting up"
Discussion in 'Electronic Repair' started by [email protected], Feb 18, 2006.
  1. Guest
    When I brought my monitor out of power-saving mode, it wouldnt start
    up. It sounding like there was a relay clicking on and off repeatedly
    followed by electrical sounds characteristic of when the monitor is
    first powered on (hum followed by high-pitched "charging" sounds).
    I ran the monitor at 1600x1200 @ 75Hz and it would be powered on all
    the time (power save mode when im not around). It was plugged into a
    belkin kvm switch (works with other monitors) and the problems are
    still there when i disconnect the monitors video.
    When I look into the unit through the vents i see no sparks, smoke, nor
    do i smell anything burning.
