dell,monitor173 lcd solved
gerry myles
Feb 28, 2009
5
Feb 28, 2009
5
The original problem no pic and flashing indicator i found two of the c5707 were shorted could not find any other fault.replacing these two transistors the unit fired up and worked for about two hours on checking again i found one of the transistors i had replaced and one of the other pair had shorted still could not find anything else wrong replacing these two the unit fired up again and this time it worked for a week and off again.I ordered 6 of these transistors and when they arrived i noticed they were from two batches 4 of them were 6L and 2 were5L so i fitted the 4 6Ls and the unit has not missed a beat for 5 months may i add that all the other transistors were 5Ls .Hope this helps someone.Gerry Myles
