Dell monitor problem
Discussion in 'Electronic Repair' started by DJR, Jul 31, 2004.
  1. DJR
    DJR Guest
    Hi, I recently got this Dell 14" monitor from my cousin who was
    throwing it away. He told me that when it got warm after 15 mins image
    will get very bright, almost white and image will be blurry. I tought
    it could be an easy fix, so I kept it. In fact, when it got warm,
    image got bright and blurry. I adjusted the brightness and focus and
    got rid of the problem. Image is very crisp and fine, colors are
    excellent, BUT after around 2 hours of usage the image will slowly
    start to get blurry again, so I have to go and adjust the focus again.
    May flyback be at fault ?
    Any suggestions ??
    Thanks a lot.
  2. Jerry G.
    Jerry G. Guest
    This is usual caused by the HV module. If it is part of the flyback, then
    the flyback must be changed. If it is separate, then it is changed as a
    separate module. Your problem would be to find parts for this monitor.
    It is also possible that there may be caps or some other types of components
    going leaky (resistive or opened) in the focus and screen bias supply to the
    CRT. This would most likely be on some of the outputs of the HV multiplier
    to the CRT. If this is the case, these components may be temperature
    sensitive.
    Most of the time when I had this type of fault, it was the HV module.
    Jerry G.
    Any suggestions ??
    Thanks a lot.
  3. techforce
    techforce Guest
    Could be the FBT. Post the Model Number and or FCC ID of the Dell, and if
    there is a White Sticker on the Flyback itself, post that info too, and I
    can tell you if its readily available.
    | Any suggestions ??
    | Thanks a lot.
  4. DJR
    DJR Guest
    Forgot, do you think would be a good idea to replace any electrolytic
    caps in the way or may I check on something else?
    THanks a lot.
  5. DJR
    DJR Guest
    Hi, it is a Dell E551a.
