Dell 2001FP LCD monitor too bright!
Discussion in 'Electronic Repair' started by Thomas Nulla, Feb 27, 2004.
  1. Thomas Nulla
    Thomas Nulla Guest
    Even with the OSD 'brightness' turned all the way down to zero, the
    backlighting is too intense to give a deep black background to the screen I
    prefer. I'm using the DVI inputs, so the 'contrast' control is disabled.
    Are there internal adjustments to decrease the brightness of the backlight?
    Is it possible to insert a sheet of translucent gray plastic (a poor man's
    neutral-density filter) between the lamps and the LCD?
    I'm reluctant to open up this costly toy just to see. :) Any sites with
    diagrams showing the internal construction of LCD monitors?
    Any other ideas, that wouldn't affect image quality?
    Thomas
  2. Jerry G.
    Jerry G. Guest
    Without seeing the monitor, I would not be able to judge how black it is.
    Someone who is used to servicing monitors, and are used to them, can tell
    you right away if the monitor is normal or not.
    All LCD displays do not go down to zero black. There will always be some
    breakthrough. They are actually best in a slightly or moderately (not too
    bright) lit room, rather than a very dark room.
    We have 3 LCD monitors at our site, and they are all slightly lit when
    totally black and powered up, when looked at in a normal room. This is one
    of the faults of these monitors when used for precise photo finishing. This
    effect will produce inaccuracies in the very dark grey's and black levels.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Thomas
  3. Thomas Nulla
    Thomas Nulla Guest
    I guess I will have to learn to live with less-than-perfect blacks. Too
    bad, other than that it's a wonderful monitor.
    Thomas -email replies: remove delthis to reply-
    http://home.austin.rr.com/tnulla/index.htm (high fidelity, liquid PC)
    "Closed orders and secret societies, whether they be religious
    or governmental, are the groups that have the hardest time reforming
    themselves in the face of failure without outside input." David Kay
