Delayed Problem with Floppy Disk Drive
Discussion in 'Electronic Repair' started by Brad, Dec 3, 2006.
  1. Brad
    Brad Guest
    I have a Compaq Contura 410C laptop (bought around 1997) which
    I do not use a lot. When I first power it up (external power, not battery),
    the floppy disk drive works just fine for about 10 minutes. Afterwards,
    I have trouble reading floppy disks (drive not ready type of problem).
    I tried a different power supply, but that isn't the cause. Could this
    problem be something other than the floppy drive?
    Thanks in advance, Brad
    Before you type your password, credit card number, etc.,
    be sure there is no active keystroke logger (spyware) in your PC.
  2. Did you let the battery charge for awhile or does this laptop run fine
    even with no battery installed?
    Could be a controller, power supply, or cable problem. It is probably
    worth reseating internal cables and PCBs if it hasn't been used for a long
    time.
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  3. JR North
    JR North Guest
    The first thing to do is clean the floppy drive and then retry.
    JR
