delay circuit
Discussion in 'General Electronics Discussion' started by behi2011, Oct 9, 2011.
  1. behi2011
    behi2011
    Oct 9, 2011
    i want a circuit for herein application:
    [​IMG]
    when i turn on the SW ,the relay activated after seconds
    but because of low impedance of relay(160 ohms), this circuit did not work
    my question is: how i can solve this problem?
    is there any high impedance 12V relay that can i use it
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    A good method is to use a much higher resistance to give a longer time constant and then a transistor (FET) to switch the relay. Relays with built in transistors are available but are expensive.
    A few seconds is possible but to go much longer brings capacitor leakage as a significant factor.
    Duke
  3. behi2011
    behi2011
    Oct 9, 2011
    can you design a circuit
  4. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Sketch attached. The time constant is R*C but the time will depend on the voltage at which the fet turns on.
