B
Brett
I want to make a degaussing coil. I don't have a used one from from a
TV. Anyone have a good idea for materials? Thanks to all.
Brett said:I want to make a degaussing coil. I don't have a used one from from a
mike said:Not at all clear what you want to do with it.
If you want to demagnatize a crt, you can make a quick and dirty
one with one big turn of #10 wire chucked in an old weller soldering gun.
mike
Return address is VALID.
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Compaq Aero floppy,ram,battery.
FT-212RH 2-meter 45W transceiver. 2-meter linear
Toshiba & Compaq LiIon Batteries, Test Equipment
30pS pulser, Tektronix Concept Books, spot welding head...
Sorry, I do want de-magnetize a CRT. I am curious now how to make one.
I tried, but I'm not sure how much current flow is necessary to create
a decent magnetic field. I tried a 2 watt/12k ohm resistor in series
with the coil. Calculated current was extremely low, in the micro amp
range. I didn't use magnet wire for the coil, regular 14-16ga wire
wrapped around an iron ring 3 times. Needless to say, the electron
beam didn't flinch when rubbed all over the face of the CRT.
Sam Goldwasser said:Figure something like 200 Amp-turns, give or take a few. In other
words, 1 A through 200 turns of wire or 100 A with 2 turns. You can
make one that will work reasonably well with about 100-200 turns of #20 or
fatter wire in a 6 inch coil in series with a 300 W (115 VAC) light bulb.
I may be off by a factor of 2 one way or the other but this should get
you started.
--- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
| Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header is ignored.
To contact me, please use the feedback form on the S.E.R FAQ Web sites.
Wouldn't the flux of the powerful alternating coil swamp out any residualBob said:Brett,
Yes, iron will most definitely increase the magnetic flux and the
resulting strength of the electromagnet, but iron also has a tendency
to retain its magnetism after the electrical field has been removed.
If you want to observe this phenomenon first hand, take a large steel
nail and wind it with enough wire to create decent electromagnet
using a small DC voltage source of your choice. Connect the source
and then use the magnet to pick up some small items (steel tacks or
paperclips work well) and then remove the voltage source while the
items are still attached. You will notice that the items are not
released immediately, but instead stay attracted to the steel
nail/core for a brief instant after the voltage has been removed.
With a de-gaussing coil, you are using alternating current (60 hertz)
to change the orientation of the field 60 times a second. You are
using this alternation in the poles to de-magnetize the item you are
de-gaussing. My concern with using the iron core is that I'm not
sure how quickly the magnet will be able to switch orientation with
the steel/iron core. Also, with the iron core, you will get a short
duration of a potentially high strength "permanent" magnet from the
last AC cycle seen prior to removing the voltage source and if you
are still close could leave the item being degaussed magnetized (just
like when you started).
