Definitions for op amps?
Discussion in 'General Electronics Discussion' started by 24Volts, Nov 4, 2013.
  1. 24Volts
    24Volts
    164
    Mar 21, 2010
    Hello,
    I have done some op amp calculations, but I am a little confused about equation definitions. In reference to attachment, can someone please confirm the following definitions in respect to gains:
    Inverting configuration:
    G1 = -rf/ra
    Non-Inverting configuration:
    G1 = -rf/ra
    G2= (r2/(r1+r2)) (1+(rf/ra))
    QUESTIONS:
    1) Isn't this a gain on its own as well (and what do we call it):
    (r2/(r1+r2))
    2) And isn't this a gain on its own as well (and what do we call it):
    (1+(rf/ra))
    Coonfused :confused::confused:
  2. Laplace
    Laplace
    1,252
    185
    Apr 4, 2010
    Attached image extracted from Texas Instruments Application Report SLAA068A - April 2000 "Understanding Basic Analog – Ideal Op Amps"
    It explains how to analyze the op-amp differential amplifier circuit shown in your image.
  3. 24Volts
    24Volts
    164
    Mar 21, 2010
    Hi LaPlace, I would like to ask you a question... if I may!
    In reference to another attachment in this post, I know it is possible to make an input ramp to the non-inverting side from 4 to 6Vdc and an output ramp of 2 to 3Vdc.... with r1 = 7500 and r2 = 2500 ohms and with ra and rf being 10K.
    But why is it we can't do an input ramp of 4 to 6Vdc with an output ramp of 2 to 4Vdc :confused:
    G2 = (4-2)/(6-4) = 1
    So now how do we figure out the resistors???
  4. BobK
    7,682
    1,689
    removed, incorrect solution.
  5. 24Volts
    24Volts
    164
    Mar 21, 2010
    Hi Bob,
    okay, but what I meant to ask is.... is there any values of resistors
    that would satisfy that circuit for that I/o ramp without modifying or adding
    anything to the circuit.
    and if not, then why? we seem to be able to do it with ramp output of 2 to 3 Vdc
    why not 2 to 4 Vdc?
  6. BobK
    7,682
    1,689
    Actually, my solution above would not work.
    You cannot do it because a non-inverting amplifier cannot have a gain of 1.
    There should be a way to make a difference ampliifer to subtract 2 from the input, but I am failing at coming up with the right configuration.
  7. BobK
    7,682
    1,689
  8. 24Volts
    24Volts
    164
    Mar 21, 2010
    okay...
    is this because of:
    (1 + rf/ra) can't be equal to 1 ???
    thanks BobK I appreciate your help
  9. Laplace
    Laplace
    1,252
    185
    Apr 4, 2010
    Recall from Algebra I that a straight line is defined by a slope and zero intercept. Your circuit, regardless of the resistor values, has a zero intercept of zero, i.e., zero at the input produces zero at the output. So instead of one of the circuit inputs being grounded, it would need to be adjusted to provide the zero offset for your defined transfer characteristic (which is non-zero).
    Also, a non-inverting amplifier with a gain of 1 is called a voltage follower.
  10. 24Volts
    24Volts
    164
    Mar 21, 2010
    thanks all for your help.
