Definition of Subscriber?
Discussion in 'Security Alarms' started by JW, Oct 6, 2005.
  1. JW
    JW Guest
    HI,
    If you had a commercial account with the instructions stating to notify
    subscriber on a particular signal, would you go to the call list if the call
    came in after hours or stop at calling the site (two monitoring centers
    handling it differently). Since they define subscriber as owner or
    authorized user(s), I'd think going to the call list would be appropriate.
    What do you think?
    Thanks.
  2. Frank Olson
    Frank Olson Guest
    Interesting. We don't call them "subscribers". They're "accounts", and the
    operators follow the instructions on the alarm screen that appears in front
    of them when a signal is received. On a commercial burg that means
    contacting the people on the list (starting with #1) only *after* the police
    have been dispatched.
  3. Joe Lucia
    Joe Lucia Guest
    I think "Subscriber" would imply trying to contact the person
    responsible for the alarm system. On a commercial account that would
    mean calling down the call-list until someone is reached. On a
    residential it would mean just calling the premises and any other
    wireless numbers the owner may have, but not the others on the call
    list.
    Depending on the time-of-day, they may want the premises tried or not,
    if the account gets setup properly then the system knows what to do at
    what times and prompts the Operators appropriately.
    It really comes down to "what did you TELL them to do in that scenario"
    since all monitoring centers tend to do things differently based on
    their flow of signals and how automated things are. If somethings
    becomes too cumbersome for their operators, they either automate it
    (sometimes too much), or stop doing it (like calling down call lists
    because it is time consuming). Not that they Won't do it, they just
    stop doing it as SOP and instead only when requested specifically to do
    so.
    Review the default actions the monitoring center will take under each
    circumstance and make sure it is taylored to the way you want it done
    for all accounts in general, then taylor the individual accounts as
    necessary from there. A good Monitoring Center can handle every signal
    any way you want, as long as it is communicated to them properly and in
    advance.
  4. Crash Gordon
    Crash Gordon Guest
    We would cycle through the call list as per how the account was set up by
    the subscriber/owner whatever you want to call them. This "may" mean calling
    the premises again if a fresh signal comes in later...just depends on what's
    happening.
    | HI,
    call
    | What do you think?
    | Thanks.
  5. JW
    JW Guest
    We said to contact the Subcriber. Instructions were on from an a former
    center where it meant to try the site, then the call list. The new center
    says they only call the site when it says to contact sub (although their
    manual defines subscriber as the owner or authorized user). We had a freezer
    signal come in, they said they only contacted the premise since the account
    had special instructions to contact the sub and account instructions
    supercede our dealer instructions that stated to contact someone.
    Ironically, the operator pended the event and contacted home numbers seven
    hours later, after employees had left for work. I'm being told it was
    handled appropriately because the special account instructions said to
    contact the sub and to them that means the site only (even on empty
    commercial buildings). I thought it was poor and wondered how other
    companies would interpret it.
    Thanks.
  6. Crash Gordon
    Crash Gordon Guest
    If they went through the call list it still shouldn't have taken 7 hours, if
    Im reading this right.
    | > list.
    | > so.
    | > advance.
    freezer
    account
    | Thanks.
  7. JW
    JW Guest
    The call came in around 1am. They called the site and then put the account
    on hold until after 8am. Then they tried the home numbers. Now I'm trying to
    be convinced that the account instructions meant - only call the site (yey
    the operator must have theought iyt meant contact the others because she
    tried (much later). So what does "contact the subscriber" mean to you?
  8. Guest
    Here, you have to contact the contacts list first, then if you get no
    answer you then contact the police. The police really dont want to
    know about it unless it is a serious issue here. As it is, you are
    lucky to have the cops turn up.
    So any time of the day or night, contacts first, police second. The
    contacts can normally vouch for false alarms or whether to call the
    cops or not.
    They also call the location if it is during hours, if it is say a panic
    button, to confirm, as that is the biggest cause of false alarms down
    here with businesses.
  9. Norm Mugford
    Norm Mugford Guest
    Sounds to me like the operator did not respond per instructions,
    and when the supervisor came in around 8 o'clock he/she caught
    it and tried to correct it. IMO
    Norm
  10. Crash Gordon
    Crash Gordon Guest
    Yah, I agree. I think they dropped the ball, 7 hours can be costly on a
    freezer alarm - the dispatch instructions should clearly be re-written to
    contact someone at anytime and not to pend it.
    | hours,
    | > > if
    account
    trying
    | to
    (yey
    | Norm
  11. Nomen Nescio
    Nomen Nescio Guest
    Special instructions are a curse. If there is any way in hell an operator
    can misinterpret them, an operator will do so, and at the very worst
    possible moment. I'd look at the exact wording if I were you, and see if
    that had anything to do with it.
    What you are supposed to do is probably spelled out in your contract
    someplace. To me, "notify subscriber" means "notify the subscriber!" You
    keep a list of names at the central station so you know who to notify.
    First, you call the premises and try to notify someone on that list, unless
    of course you know the place is closed. If you don't succeed in notifying
    them at the premises, you notify them by calling the phone numbers they
    provided. After all, that's why they gave you their phone numbers, right?
    Notify means notify. Don't make this more complicated than necessary.
    Your CS is trying to feed you bullshit.
  12. Nomen Nescio
    Nomen Nescio Guest
    "Hi, this is ABC Security. Are you being robbed?"
  13. Crash Gordon
    Crash Gordon Guest
    Almost as dumb as calling *residential* alarms on AC Fail to tell them their
    power is out. You nummies we know its out we're sitting in the dark talking
    to you!
  14. Crash Gordon
    Crash Gordon Guest
    First I delay AC fail for one hour. Then I call on low battery if the fail
    lasts that long.
    I had gotten so many complaints abt calling on AC fail that I stopped doing
    it...residential only...and exceptions being if there's a life support
    device in use or wine cellar or freezer alarm or something like that.
    | We call on AC Fail... How do you know the power is out in the whole house,
    | maybe some accidentally unplugged the panel's transformer.............
    | Regards, Russ
    | > their
    | > talking
    | > to you!
    panic
  15. Crash Gordon
    Crash Gordon Guest
    We get TONS of power fails here during monsoon season...calling on them all
    is nuts.
    I know a local company that will dispatch on AC fail - they had a problem
    once and can't seem to get over it.
    |I delay AC fail reports for two hour normally..... Maybe that's why I
    | haven't received any complaints yet (fingers crossed).........
    fail
    | > lasts that long.
    | > doing
    | > house,
    | > | Regards, Russ
    them
    | > | > their
    | > | > talking
    | > | > to you!
    | > panic
    | > down
  16. R.H.Campbell
    R.H.Campbell Guest
    I agree ! Why would you want to flood the station with useless AC fail
    signals anytime there is a major power outage (very common around here).
    Unless there is a specific reason for using it (as you mentioned), I disable
    it as a matter of course. Still can't figure out why most installers leave
    it programmed in to the station, and even more surprising, is why monitoring
    stations put up with it.
    RHC
  17. Guest
    thats what they have to do though, the cops wont go if they dont call
    to confirm first. I know its stupid but hey ... thats why they have a
    passcode and also if they dont anwer the phone then they call the cops
    anyway ..
  18. Crash Gordon
    Crash Gordon Guest
    I use it because I DO want to know about them, as there could be a problem
    but certainly not dispatch. On commercial we do call an RP.
    disable
    monitoring
    | RHC
    | > all
    | > is nuts.
    problem
  19. alarman
    alarman Guest
    Same here. I see all the account activity first thing in the AM. If I don't
    see a restore, I'll call the customer. 99% of the time the restore comes in
    within an hour or 2.
    js
  20. alarman
    alarman Guest
    Monsoons? In AZ??
    js
