Decrease voltage from 53V to 48V
Discussion in 'General Electronics Discussion' started by mubidx, Mar 5, 2009.
  1. mubidx
    mubidx
    Mar 5, 2009
    hello
    I have a equipment which works on 46 to 48 volts DC the problem is the power supply i have it's output is 53 volts DC I am wondering is there anyway to decrease the volts using somehing between the supply and equipment ???
  2. pendragon
    pendragon
    5
    Aug 28, 2009
    mubidix
    what is the current requirement of the equipment you intend to run ??
  3. amdNRA
    amdNRA
    50
    Sep 3, 2009
    You can use a pass power transistor (2N3055) with a zener diode and biasing resistor in the base configuration OR just a zener diode in series by itself. Bear in mind that the 'zener diode only solution' will require a higher current zener. The zener will have to be in the 5 to 7 volt range aproximately (53V-46V=7V). Like Pendragon says, figure out the current and take it from there.
    Later, Gil. :)
  4. jamygdala
    jamygdala
    6
    Jul 13, 2009
    For high currents I have used several forward biased diodes to create small-ish drops. nb Vf will change for different currents - check data sheet graphs
    Diodes connected in series - to be clear ;-)
