decoder for 8051
Discussion in 'General Electronics Discussion' started by vead, Oct 23, 2014.
Thread Status:
Not open for further replies.
  1. hevans1944
    hevans1944 Hop - AC8NS
    4,606
    2,151
    Jun 21, 2012
    So please do what was asked to demonstrate you understand how an instruction is assembled for the 8051 from an 8-bit op code, plus one or two byte operands (if needed).
    Why not encode MOV R4, #5 and MOV R3, A, and MOV A, @R1?
    See my complete post #57.
  2. hevans1944
    4,606
    2,151
    Jun 21, 2012
    I will re-visit this thread next month to see if there has been any progress made.
    vead likes this.
  3. (*steve*)
    25,489
    2,830
    Sorry I'm not going to respond further.
    (edit: either)
  4. vead
    vead
    473
    14
    Nov 27, 2011
    you asked question Why not encode MOV R4, #5 and MOV R3, A, and MOV A, @R1?
    I have given answer
    data and address are available in registers that can be access by using register address
    so thats why we don't encode MOV R4, #5 and MOV R3, A, and MOV A, @R1?
    we can simply store data into respective registers
  5. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    OK, I'm going to have another go.
    I don't think you have grasped even the basics of how an MCU core executes code. I want to take one example case and go through the process that the core uses execute it, step by step, in detail, to see if you can understand it. I want you to read this description carefully, several times, and try to follow it. I will try to be as explicit as possible.
    Here is the state of some of the 8051 MCU core's internal registers, the register bank, and part of the program memory at the start of this example. I will not show the data memory because it is not used directly in this example.
    Program counter = 0x0042. This hexadecimal value is 0000000001000010 in binary.
    A register (accumulator) = 0x33. This hexadecimal value is 00110011 in binary.
    Register bank R0 = 0x00 = 00000000 binary
    Register bank R1 = 0x10 = 00001000 binary
    Register bank R2 = 0x01 = 00000001 binary
    Register bank R3 = 0x25 = 00100101 binary
    Register bank R4 = 0x00 = 00000000 binary
    Register bank R5 = 0x00 = 00000000 binary
    Register bank R6 = 0x00 = 00000000 binary
    Register bank R7 = 0x00 = 00000000 binary
    Code memory: Address 0x0040 contains 0x8E = 10001110 binary
    Code memory: Address 0x0041 contains 0x22 = 00100010 binary
    Code memory: Address 0x0042 contains 0x2B = 00101011 binary
    Code memory: Address 0x0043 contains 0x44 = 01000100 binary
    Code memory: Address 0x0044 contains 0x02 = 00000010 binary
    First, I want to check that you understand how to convert between binary and hexadecimal. There is a deliberate error on one line in the list of register values above. It does not affect the example but it is still wrong. Can you find it?
    Now I will describe, step by step, the way the 8051 core will execute one instruction, given the starting conditions listed above.
    First, the 8051 core needs to read the first byte (the opcode byte) of the instruction that it is about to execute. It sends the program counter (PC) value to the code memory's address bus, reads the byte at that address, and increments the program counter.
    This is the first instruction fetch cycle. The PC register (internal to the core) contains the current code execution address. The core needs to get the instruction that starts at that address, so it knows what to do. So it reads a byte from code memory, at the address indicated by PC, and stores it in a temporary register in the instruction decode logic. It also increments PC so it is ready for the next byte in program memory.
    In this case, PC contains 0x0042 so the core will read the byte at address 0x0042 in code memory. If you look above in the code memory section you will see that this code memory location contains a byte value of 0x2B, which in binary form is 00101011. This is the first byte of an instruction.
    Now the instruction decoding logic of the 8051 needs to figure out what instruction this opcode byte value represents. In this case, the opcode matches 00101rrr which is an "add A,Rr" instruction.
    This instruction occupies a single byte in the code memory. The opcode byte contains all the information the core needs to perform the operation. The register which is to be added into the accumulator is identified by the bottom three bits of the opcode - the "rrr" part. The top five bits of the opcode identify the type of instruction - "add A,Rr".
    So the core doesn't read any more bytes from code memory; it can start executing the instruction immediately. It knows that it needs to add the contents of the specified register into the accumulator, and it uses the ALU to do this.
    The ALU has two 8-bit-wide inputs. The instruction execution logic feeds the current value of the accumulator (A) register into one of these inputs, and it uses the bottom three bits of the opcode as an address in the register file (which is just an array of 8-bit-wide RAM) to address the register specified by the opcode. In this case, the "rrr" bits are 011 which means register R3 is being selected. So the instruction execution logic feeds the current value of R3 into the second input to the ALU.
    Then it tells the ALU to perform an addition operation. This adds the current accumulator value and the value of R3 together and the result appears at the output of the ALU. The instruction execution logic then copies that result back into the accumulator register.
    The ALU will also modify certain flags in the program status word ("PSW") register as part of the addition process.
    The instruction has now been executed. The value in the R3 register has been added into the A register, and some PSW flags have been updated. The instruction execution logic can now start executing the next instruction, which starts at code address 0x0043.
    The steps involved in decoding and executing the instruction are controlled by part of the instruction execution logic called the microcode, which is stored in ROM within the core. The microcode controls the timing of the accesses to code memory, register memory, internal RAM and SFR memory, and external memory, according to the requirements for the instruction being executed.
    When you understand that description, try to write up a similar description for what will happen when the 8051 core executes an instruction opcode of 0x14.
    Allen Bong, vead and hevans1944 like this.
  6. vead
    vead
    473
    14
    Nov 27, 2011
    first of all thank you for your cooperation
    I am sharing my big doubt
    8051 Instruction set
    5 bit opcode + 3 bit register specification
    7 bit opcode + 1 register specification
    8 bit opcode
    5 bit opcode that allow 32 operations
    7 bit opcode that allow 128 oprations
    8 bit opcode that allow 256 operations
    Many ALU can directly access program memory . so they use registers
    · Accumulator register
    · Rn register (R0 to R7)
    · Ram memory
    · Program memory
    · Instruction decoder
    · Program counter
    · ALU (arithmetic and Logic unit)
    · PSW register
    Example
    MOV A, Rn
    11101 n n n
    MOV @Ri, A
    1111011i
    8 bit opcode
    MOV A, direct
    11100101 direct
    8 bit opcode
    Q I don’t understand whats the use of three different Instruction format, how they execute ?
    I am not sure but look my answer
    I think, first two format they don’t use Instruction decoder. Data store directly to respective register, To execute this type of Instruction they don’t use ALU
    Last formmet , I think it use Instruction decoder
    how the different instruction execute in different format ?
  7. vead
    vead
    473
    14
    Nov 27, 2011
    I am doing some extra work
    Control signal that are needed to perform each type of operation
    Example
    s1s2s3
    0 0 0 control signal tell the ALU to do add operation (A and B)
    0 0 1 control signal tell the ALU to do oroperation (A or B)
    0 1 0 control signal tell the ALU to do add operation (A Nand B)
    0 1 1 control signal tell the ALU to do add operation (A nor B)
    1 0 0 control signal tell the ALU to do add operation (A Xor B)
    1 0 1 control signal tell the ALU to do add operation (A X nor B)
    1 1 0 control signal tell the ALU to do add operation (A add B)
    1 1 1 control signal tell the ALU to do add operation (A sub B)
    S1 s2 s3 c ac A B output Oc Oac
    0 0 0 x x xxxx xxxx F x x
    0 0 1 xxxx xxxx F
    0 1 0 xxxx xxxx F
    0 1 1 xxxx xxxx F
    1 0 0 xxxx xxxx F
    1 0 1 xxxx xxxx F
    1 1 0 xxxx xxxx F
    1 1 1 xxxx xxxx F
    We can d0 same with 8 bit ALU for 8051
    psw register 8 bit
    PSW register will be rember C, Ac ,O
    Input control signal...?
    Input Operand 1 8 bit
    Input Operand 2 8 bit
    Output F 8 bit
    Carry input c
    Auxilarry carry ac
    Output carry OC
    Auxiliary carry acO
    Q. what control signal that are needed to perform ALU operation for 8051?
  8. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    You just ignored my post.
    You are trying to teach yourself things that you don't understand. You are getting into details before you have even a basic understanding of opcodes and how they are executed.
    You will not learn from your own ideas. You will only learn by following the guidance of people who already understand.
    I am going to give you one more chance to try to learn from me.
    Yes, that describes part of the 8051 opcode map.
    Some opcodes are the full 8 bits wide. For example:
    0 0 0 0 0 0 0 0 nop
    0 0 0 1 0 1 0 0 dec A
    1 1 1 1 0 1 0 0 cpl A
    1 1 0 0 0 0 1 1 clr C
    Some opcodes include a 3-bit register specification. For example:
    0 0 0 1 1 r r r dec Rr
    1 1 1 1 1 r r r mov Rr,A
    0 0 1 0 1 r r r add A,Rr
    Some opcodes include a 1-bit register specification. These use a register as a memory pointer for indirect access. Let's ignore these instructions to start with.
    Let's pretend to be the 8051 core. You know it keeps track of the code execution address in code memory through the PC (program counter) register. When it's time to fetch, decode and execute an instruction, it fetches a byte from code memory at the address pointed to by the PC register.
    Let's assume that the 8051 core fetches an opcode, and that opcode is 00101011 binary. How does it know what to do? It internally decodes that instruction to figure out several things about it.
    This decoding is controlled by the microcode, which controls a whole lot of signals within the core so that the core will execute the instruction step-by-step and produce the right result.
    In principle, the microcode maps each possible first instruction byte value (there are 256 of these) to a sequence of control signals within the core. These signals cause actions like reading and writing registers, reading and writing memory, sending data to the ALU, transferring results from the ALU, and so on.
    The first instruction byte is 00101011. This is an "add A,Rr" instruction and the rrr bits a 011 which means it is referencing R3, so the instruction, in full, is "add A,R3".
    Any instruction byte that has 00101 in the top three bits is an "add A,Rr" instruction. When the top five bits contain those values, the core knows that this must be an "add A,Rr" instruction, and that the bottom three bits specify the register number.
    The microcode for that number will cause the core to send the contents of the A register to one input of the ALU, and send the contents of the register specified by the rrr field of the instruction (i.e. R3) to the other input of the ALU. Then it will instruct the ALU to perform an addition operation. Then it will load the result from the ALU into the A register.
    These micro-operations are all performed in the correct sequence, under control of the microcode. The microcode drives a whole lot of signals inside the core which control how data is channeled between internal registers (A, PC, PSW), addressable registers (R0~R7), RAM, SFRs, and code memory.
    You may know that in the standard 8051, each instruction takes a multiple of 6 clock cycles to execute. Each one of those clock cycles represents one phase of the microcode. The microcode is like a tiny, low-level program. It takes the first instruction byte and coordinates all of the internal data transfers within the core (and to the RAM and code memory) to execute the specified instruction.
    Now, if you want any more help from me, you will read and try to understand this description. If you're not sure, ask me any questions about it.
    DO NOT ask me unrelated questions as you did in your last post. You need to understand this stuff first.
    Allen Bong likes this.
  9. vead
    vead
    473
    14
    Nov 27, 2011
    I have little query about mov instruction
    How they fetch decode and execute ?
    Mov instruction
    1. MOV @Rn, #immediate encoding 0111011 r
    Operation: [email protected],#0
    MOV @R0, #0 encoding 01110110 00000000
    01110110 00000000
    This is 2 bytes Instruction
    which is fetch, decode and execute unit ?
    2. MOV @Ri, A encoding 1111011i
    Operation [email protected],A
    Mov @R0,A encoding 11110110
    11110110
    This is 1 byte instruction
    Which is fetch , decode and execute unit ?
    3. MOV dest_direct, src_direct
    MOV P1, P0
    10000101 src_direct dest_direct
    10000101 aaaaaaaa aaaaaaaa
    This is 3 bytes instruction
    4. MOV direct, @Ri
    10001 0 0 0 MOV direct, R0 Mov the content of R0 into address
    10001000 aaaaaaaa
    This is 2 bytes instruction
    Which is fetch , decode and execute unit for this instruction ?
  10. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
  11. vead
    vead
    473
    14
    Nov 27, 2011
    that's the question, that I don't understand so I asked you.
    DO I need to create another thread for these question
    actually what work do you want from me ?
  12. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    1. Don't start another thread.
    2. Do you understand post #68 in this thread?
    3. Explain (like I did in post #68) how the 8051 core will process an instruction of 00010100. (Hint: look in the "dec" (decrement) instructions.)
  13. vead
    vead
    473
    14
    Nov 27, 2011
    Ok I try to explain with following assembly program
    Code:
     address    Machine language  assembly language
      1 0000                                          ORG 0H
      2 0000        7D25                       MOV R5,#25H
      3 0002        7F34                        MOV R7#34H
      4 0004         7400                       MOV A,#0
      5 0006         2D                           ADD A,R5
      6 0007         2F                           ADD A,R7
      7 0008       2412                          ADD A,#12H
      8 000A       80FE    HERE:          SJMP HERE
      9 000C 000C                               END
    MOV R5,#25H encoding 01111 1 0 1 0010 0101 2 bytes instruction
    MOV R7#34H encoding 01111 1 1 1 0011 0100 2 bytes instruction
    MOV A,#0 encoding 01110 1 0 0 00000000 2 Bytes instruction
    ADD A,R5 encoding 00101 1 0 1 1 Byte instruction
    ADD A,R7 encoding 001011 1 1 1 Byte instruction
    ADD A,#12H encoding 001001 0 0 0001 0010 2 Bytes Instruction
    PROGRAM MEMORY
    Address code binary number
    0000 7D 0111 1101
    0001 25 0010 0101
    0002 7F 0111 1111
    0003 34 0011 0100
    0004 74 0111 0100
    0005 00 0000 0000
    0006 2D 0010 1101
    0007 2F 0010 1111
    0008 24 0010 0100
    0009 12 0001 0010
    000A 80
    000B FE
    When the 8051 is powered up, the PC (program counter) has 0000 and starts
    to fetch the first opcode from location 0000 of the program ROM. In the case
    of the above program the first opcode is 7D, which is the code for moving an
    operand to R5. Upon executing the opcode, the CPU fetches the value 25 and
    places it in R5. Now one instruction is finished. Then the program counter is
    incremented to point to 0002 (PC = 0002), which contains opcode 7F, the
    opcode for the instruction “MOV R7 , . .”.
    · Upon executing the opcode 7F, the value 34H is moved into R7. Then the program counter is incremented to 0004.
    · ROM location 0004 has the opcode for the instruction “MOV A, #0″. This
    instruction is executed and now PC = 0006. all the above instruc
    tions are 2-byte instructions; that is, each one takes two memory locations.
    · Now PC = 0006 points to the next instruction, which is “ADD A, R5″. This is
    a 1-byte instruction. After the execution of this instruction, PC = 0007.
    · The location 0007 has the opcode 2F, which belongs to the instruction “ADD
    A,R7″. This also is a 1-byte instruction. Upon execution of this instruction,
    PC is incremented to 0008. This process goes on until all the instructions are
    fetched and executed.
    the program counter points at the next
    instruction to be executed
  14. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    VEAD.
    YOUR ENTIRE POST was COPIED WORD FOR WORD from http://renusblog.codemyne.net/Admin/Post.aspx?postid=7.
    YOU WILL NEVER LEARN ANYTHING IF YOU ONLY PRETEND TO UNDERSTAND.
    I am very tempted to ban you from Electronics Point immediately for plagiarism and outright lying, and as a probable TROLL.
    I have put you on my "ignore" list. I have only ever done this with one user before.
    You will not be getting any more help from me.
    Allen Bong and hevans1944 like this.
  15. vead
    vead
    473
    14
    Nov 27, 2011
    I am really sorry, I agree It was my mistake, Some time I don't understand what suggestion do you give me It may be my English problem and definitely I will improve my English
    so please give me one chance,, don't ban me, I need one chance , give me one chance I will show you my work then decide what do you think
    vead
  16. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Vead. My suggestion to you, is to go do some reading. Find a tutorial for something that interests you and follow it.
    What you have done is not related in any way to your English skills. The proper way to go about this is to take the steps to teach yourself. Everyone on here is a volunteer, we are not obligated to share any of our time, skill, or knowledge but we choose to share.
    I think you are trying to learn too much too fast and that is why you are not understanding. You may also be trying to learn something that is too advanced for you.
    You may not realize it, but you have been given a second chance on a few occasions. Look through some of your previous topics, and you will find that most of the suggestions and tips that have been given to you are ignored.
    For now you are still here. Consider that a blessing.
    Once more. Go google some basic circuits and play with them and learn them.
    I will not participate in any of your threads unless :
    -You have a circuit diagram you are trying to build, or design.
    -You have a program you are trying to write or fix.
    -You have an electronic device that you are trying to repair.
    When you can show some progress and a genuine willingness to learn, you will find that more people will answer you.
    hevans1944 likes this.
  17. vead
    vead
    473
    14
    Nov 27, 2011
    We write assembly code on assembler like this
    Assembly code
    MOV A, # 4A ; load data 4A into A register
    MOV R1,# 5E ; load the data 5E into R1
    ADD A,R1 ; add the content of R1 into A register
    INC R1 ; increase R1 with 1
    INC A ; increase A with 1
    MOV A,R1 ; move the value of R1 into A register
    Look following way how this assembly code convert in binary form
    Assembly code
    MOV A, # 4A
    Mcahine code
    Code:
    0000  74 4A
    BINARY CODE
    Code:
    0000 0000 0000 0000  0111 0100
                                           0100 1010
    Example
    Code:
    Memory address  Hex code  assembly language  comments
    0000                     74 4A  MOV A,#4A  ; Load the immediate data into A
    Where 0000 is memory address. 74 is mov A opcode and 4A is operand
    Processor read Byte from Program memory at the address indicate by program counter
    Example: processor read Byte (0111 0100) which is opcode MOV A
    First processor(cpu) need to read first byte of instruction
    Example 0111 0100 74 first byte
    0100 1010 4A second Byte
    So processor read Byte form program memory at the address 0000 indicate by program counter and Store Data 4A into Accumulator registor
    So program counter increament and its ready for next bytes in program counter
    Ok If next memory address is 0002
    Assembly code
    MOV R1,# 5E
    Mcahine code
    0002 79 5E
    Binary code
    processor read Byte (0111 0100) which is opcode MOV R1
    So processor read Byte form program memory at the address 0002 indicate by program counter and Store Data 4A into Accumulator registor
    Again program counter increament and its ready for next bytes in program counter
    Ok If next memory address is 0004
    Assembly code
    ADD A,R1
    Machine code
    0004 29
    Assembly code
    ADD A,R1
    Machine code
    0004 29
    Code:
    0000 0000 0010  01111 001
                                 0101 1110
    Code:
    Binary code
    00000 00000  0100  00101001  (00101rrr)
    0004                      74  ADD A,R1  ; Add the content of R1 into A
    So the processor doesn't read any more bytes from program memory; it can start executing the instruction immediately. It knows that it needs to add the contents of the specified register into the accumulator, and it uses the ALU to do this.
    8051 has 8 bit ALU
    The instruction execution logic unit store the current data 4A of Accumulator into the Input of ALU
    And instruction execution logic unit store the current data of R3 into the second input to the ALU
    ALU also use pse register toremember carry auxillary carry overflow …
    Then the program counter is incremented to 0005.
    Assembly code
    INC R1
    Machine code
    0005 0B
    Binary code
    0000 0000 0101 00001 001
    The instruction execution logic unit will Increment R1 register
    Increment program counter to next Instruction 0006
    Assembly code
    INC A
    Machine code
    0006 04
    Binary code
    0000 0000 0110 00000100
    The instruction execution logic unit will Increment A register
    Increment program counter to next Instruction 0007
    Assembly code
    MOV A,R1
    Machine code
    0007 E9
    Binary code
    0000 0000 0000 0111 11101001
    Now the code look like in assembly
    Assembly code
    Code:
    Machine code
    Code:
    0000  74 4A
    0002  79 5E
    0004  29
    0005  0B
    0006  04
    0007  E9
    Binary code
    Code:
                                         0100 1010
    0000 0000 0000 0010  01111 001
                                          0101 1110
    0000 0000 0000 0100  00101001
    0000 0000 0000 0101  00001 001
    0000 0000 0000 0110 00000100
    Finally to understand someone
    Code:
    Assembly code
    0000          74 4A       MOV A, # 4A  ; load data 4A into A register
    0002          79 5E        MOV R1,# 5E  ; load the data 5E into R1
    0004           29         ADD A, R1  ; add the content of R1 into A register
    0005           0B          INC R1  ; increase R1 with 1
    0006           04         INC A  ; increase A with 1
    0007          E9        MOV A,R1  ; move the value of R1 into A register
    Program memory will be following
    Code:
    Memory address opcode operand
    0000                    74 4A
    0002                        79 5E
    0004                         29
    0005                       0B
    0006                       04
    0007                        E9
    Program counter will be following
    Code:
    0000 0000 0000 0000
    0000 0000 0000 0010
    0000 0000 0000 0100
    0000 0000 0000 0101
    0000 0000 0000 0110
  18. davenn
    davenn Moderator
    13,810
    1,944
    Vead
    Im going to close this thread for now, as the 2 people that were trying to help you have stopped doing so
    so please no more on the 8051 or similar device OK
    have a think about something a little more simpler .... maybe come up to something more modern like a PIC or similar micro controller
    Do some reading and learning for a start on your own
    if you have some questions then start a new thread
    cheers
Thread Status:
