Debug Speed of ETM Trace for Debugging IO
Discussion in 'Electronic Design' started by Kvik, Apr 3, 2013.
  1. Kvik
    Kvik Guest
    Hi
    I have an input pin that I suspect is pulled to the wrong state due to
    noise. I have no way to measure the pin since it's burried in inner
    layers of the PCB
    The pin frequency is max 100kHz and I have input filtering (derived
    from the CPU clock frequency) on the pin so I know the frequency is
    lower than about 10MHz
    So I have two ways forward:
    1: Make a loop to capture the input pin, store that in RAM, and at a
    trigger event, stop that capture, and send it all via a UART to a PC
    for analysis. I can overclock the CPU to run above specified 32MHz to
    capture this possible event if needed...
    2: Use the internal ETM (Embedded Trace Macrocell) to store to the PC
    runtime in the Keil uVision environment with ULink2 debugger.
    "2" is simpler, but anyone know how fast the ETM runs on a ST Cortex
    M3 (STM32L151) and is it with fixed interval sampling?
    Regards
    Klaus
  2. Can't you do 1) but just examine/dump the memory directly with the
    debugger? Don't know anything about Keil but in gdb you can just dump an
    array to a file, or any debugger should let you view the array contents.
  3. Guest
    maybe instead of storing the pin state copy it to another pin that you
    can measure?
    -Lasse
  4. Yes, that was my first thought, but I have no pins readily available
    Regards
    Klaus
  5. It needs to be done runtime, since that is when the fault happens and I cannot stop the core for debugging
    Cheers
    Klaus
  6. Guest
    do you need the ETM at the same time? can't those pins be used as
    GPIO?
    -Lasse
  7. I have found that on cortex-m3, you can actually dump variables without
    stopping the core! (I was amazed when I did it by accident and it
    worked.). It's very cool, you can capture the current state of a running
    system.
    Of course this does take some finite time so may have to arrange a
    trigger of some kind otherwise a circular buffer of pin states might
    wrap around multiple times while it is being read out.
    This was with STM32F2 and openocd, but would think it is same on others.
