Dead RCA
Discussion in 'Electronic Repair' started by Rufus T. Firefly, Oct 9, 2003.
  1. I have a RCA 35" (F35731MB c.1995) that has just died. I suspect it was the
    power supply because it had gone out and been repaired in the past. I don't
    think I'll be repairing this a second time. Time to move on to a new set. My
    question is does this TV have any value to anyone? Or is it just a 250lb.
    anchor? Also, what would be a good replacement? I'm not ready for HDTV so
    I've been eyeing a Sony KV-36FV310 36". Thanks in advance.
  2. David
    David Guest
    Where are you located? email me if near N.E. Indiana.
    Definitely find out if someone will fix the set before putting it in the
    landfill.
    As to the value, broken, it is worth zero. Actually it will cost you to
    throw it away in most parts of the US now.
    As to the problem with the set, there are way too many things beyond the
    power supply that must be working before the tv will turn on it could be
    anything.
    David
  3. Guest
    If you're anywhere near Spokane, WA I'll come pick it up.
  4. I'm in the Sacramento, CA area.
