I have a circuit with 4 3w LEDs in series. There is a Voltage regulator on the + end with an incoming voltage of 24v. The voltage regulator appeared to be dead so i replaced it. The LEDs still do not work. Is it possible that when the voltage regulator died (win tested it had 24v on the output) it has killed the LED's? Is there an easy way to test if the LED's are ok?
Categories
Platforms
Content
