Dead HP Pavilion v70 Monitor
Discussion in 'Electronic Repair' started by [email protected], Apr 24, 2005.
  1. Guest
    Hello,
    I'm quite new to electronics repair but I believe I do have a basic
    understanding of things. I've spent the better part of today
    troubleshooting a dead monitor. The monitor is an HP Pavilion v70,
    model number: P3209S, chassis: Tatung C7Es.
    I've followed the FAQ a bit and tried to determine what I should do but
    I've gotten stuck. Over the past couple of weeks the horizontal
    deflection would cut out occasionally (wouldn't come back with a gentle
    whack) and would be fine after shutting it off to rest for a few
    minutes. Also, the picture's vertical deflection would squash down
    about an inch on top and bottom, but this could be fixed with a gentle
    tap, so I suspect it was just a loose connection.
    A couple days ago it decided that it would not power up at all. There
    are no indications of power (no static, no clicks, no lights, etc.)
    Upon opening the case and plugging it in, if I listen closely I hear it
    clicking quietly like a clock (as in the FAQ.) I've tested the HOT and
    it appears to be shorted out and I don't measure voltage on it. I'm
    not sure I'm measuring it correctly, but I'm putting my black lead on a
    ground and the red lead on each leg of the HOT. I read 0V on each one.
    Now, I've come to the conclusion that I should replace the HOT, but I'm
    not sure if this is the right course of action, nor am I sure if it's
    the full problem. I'd like to know if I've done everything correctly
    and what I should do next. I have access to a multimeter, 100MHz
    oscilloscope, and an ESR meter. If there is any information that I'm
    missing, I'll be happy to give more details if I'm able. I'd
    appreciate any help in repairing this monitor.
    Thanks!
    James Bailey
  2. James Bailey
    James Bailey Guest
    Okay, what I've gathered so far:
    - Remove HOT and test properly, replace if necessary
    - Heat caps and test ESR, replace bad caps
    Is this generally all I need to do? Do I need to check for blown
    fusable resistors, etc.? I figure I need to do that considering I
    don't have voltage running to the HOT (if I'm measuring this correctly
    - probe to ground and probe to leads of HOT).
    Thanks again!
    James
