D
First off, I haven't done much work with IC's. Last night I wanted to
replace a 20-pin DIP IC. I read various news posts on the subject, bought
myself a desoldering vacuum pump (hand operated squeeze-bulb type), replaced
my aging desoldering braid (good brand, got from digi-key on good advice).
So I heat up my iron, apply the braid, ZOOP, up comes the solder into the
braid. HEY, I says to myself, this ain't so hard. Repeat on the other 19
pins. Let things cool down for a minute or so, try to jiggle the IC loose.
Uh-uh. No way. Ain't gonna' budge. There seemed to be enough residual
solder on the pins to keep them from loosening.
To make a long story short, I used brute force to remove the body of the IC
and heated and removed the pins one by one with a pair of tweezers. The I
heated each hole and shoved a 22ga wire through to clean out the solder.
All the time I was doing this I kept thinking "I am pretty sure the guy at
my local electronics shop does not do this". So, the story has a happy
ending, the new IC is installed.
What is the proper method for removing an IC? Should the solder braid have
taken up enough solder to remove the chip? Am I using it wrong?
