spikey1973
- Jul 16, 2014
- 32
- Joined
- Jul 16, 2014
- Messages
- 32
Hey Guys (and galls)
I got my hand on a muRata MVAC400 Series PSU
https://power.murata.com/data/acdcsupplies/mvac400.pdf
now i want to go and connect it and found that the main output (J2) has 6 pins +DC_out and 6 pins +DC_out_rtn as 12 pin molex connector output.
unfortunately i am unfamiliar with this +DC_out_rtn terminalogy, i assume rtn means return? and therefor use +DC_out as Positive and +DC_out_return as Negative and use this as 24VDC out, or does this mean something else, and should i take other things in consideration here (before) i can use it as 24VDC. and if is isn't exactly the same then what is the difference?
i ask before i try to measure as last time i measured something i didn't fiully understood i blow up a PSU.
kind regards
Matt
kind regards
Matt
