b
Hello people. I've got a simple question, Is it possible to measure a voltage multiplier or does it just multiply charge?
Yes, use a ruler and measure it in centimeters.
Your question does not make any sense.
Voltage multiplier usually refers to a circuit that takes in AC, runs in through a string of diodes and capacitors to produce a DC voltage that is a multiple of the input minus some diode drops. You can measure the output voltage if that is what you mean, with a multimeter. Multiplying charge does not make any sense, you cannot create charge, only move it around.
