DC to DC converters
Discussion in 'General Electronics Discussion' started by Moha99, Dec 3, 2011.
  1. Moha99
    Moha99
    261
    Nov 18, 2011
    Hallo!
    Recently I bought a DC to DC converter to step up my input voltage.
    I bought the RECOM RCD-24-0.70 dc to dc converter listed here in the site:
    http://docs-europe.electrocomponents.com/webdocs/0aba/0900766b80aba022.pdf
    Its the 5th one.
    I want to convert 6volts DC to 12 volts DC using this exact product.
    I tried wiring up a "Dimming control" to increase the voltage but I get nothing... 6 volts In 6 volt out
    And the products states its adjustable output voltage...
    Can anyone help me with this and if you know the solution please clarify the answer.
    Thank you
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    What did you use for a load?
    Oh, and besides, how do you expect stepping up a voltage with a step-down constant-current source/driver/converter?
  3. Moha99
    Moha99
    261
    Nov 18, 2011
  4. davenn
    davenn Moderator
    13,765
    1,920
    Hi Moha
    as Res is indicating your have misunderstood the purpose of this DC - DC converter
    Firstly it is designed for driving LED's with a constant current
    Secondly its a step down converter NOT a step up converter
    read the first line of the description......
    you are NEVER going to get more voltage out than what you put in
    the one you chose... RCD-24-0.70 has an adjustable output up to ~2.5V bvelow the input voltage 4.5V in 2V out; 36V in adjustable up to 33V out
    There are other boost DC - DC converters out there do a google search on those words
  5. davenn
    davenn Moderator
    13,765
    1,920
    Yes thats a step up regulator but 2 things to consider.....
    1) its surface mount and unless you have the soldering station capable of doing SMD work you are going to find it really difficult to work with
    2) it only has 70mA current capability
    you havent said what you want to use the converter for but this may be way too low in current capability.
    You would be much better off with a LM1577/2577 switching regulator, it can on its own do up to 800mA (0.8A)
    google the datasheet :)
    cheers
    g
  6. Moha99
    Moha99
    261
    Nov 18, 2011
    Aha thanks!
    Im looking for any boost converter that will increase an input voltage of 6VOLTS/DC to any voltage to power some dc appliances btw they are all under 1 AMP so its fine.
    I found a group of Dc to Dc converters the maximum output current is not stated or even the minimum because the voltage output is adjustable.
    So I just need voltage of 12 and above.
    I found theses converters:
    http://sa.rsdelivers.com/product/li...-adj-3a-su-boost-dc-dc-converter/5060748.aspx
    and this too
    Which are pretty good for me.
    What do you think?
    Keep in mind I don't need much amperage. 500mA is good 700mA is better 1Amp is perfect.
    I think one of them could get me close to the requirements.
  7. davenn
    davenn Moderator
    13,765
    1,920
    ok those were both the same link :)
    but yes you are on the right track now :)
    have fun and report back on how you got on
    cheers
