DC to DC converters
Discussion in 'Misc Electronics' started by john, Jul 20, 2005.
  1. john
    john Guest
    Hello,
    I am looking for some good application notes regarding
    How to use isolated DC to DC converters.
    Plus I am also looking for a isolated DC to DC conveters with following
    specifications
    If they are regulated, then that would be great!
    1. Input Voltage range : 5 to 6Volts
    Output voltage : 5volts
    output current: 5 Amp.
    2. Input Voltage range : 18Volts
    Output voltage : 18 volts
    output current: 3 Amp.
    3. Input Voltage range : -18 Volts
    Output voltage : -18 volts
    Thanks very much.
    Regards
    John
  2. exxos
    exxos Guest
    Isolated from what to what ? A wall plug PSU is isolated from the mains via
    a small transformer.
    Chris
  3. john
    john Guest
    Isolation between input and output of the DC to DC conveter.
    Regards
    John
  4. john
    john Guest
    Regards
    John
  5. john
    john Guest
    Regards
    John
  6. exxos
    exxos Guest
    what are you using to power the DC source with ?
    Chris
  7. john
    john Guest
    Hello,
    I am using DC power supply.
    Regards
    John
  8. exxos
    exxos Guest
    I dont know of anyway apart from just use something like a 20V DC PSU, then
    just put fixed or adjustable regulators to get the voltages you want. I
    don't see why you need them isolated ?, if you worried about short circuits
    then fuse it or crowbar it for protection. Isolation of DC sounds like a lot
    of work IMO.
    Chris
