Thanks. Can you give a Circuit diagram of an Oscillator+Amplifier which will generate 12V AC from a 12V DC voltage input ?
@kellys_eye is saying you may not need it. Most medical electronics equipment runs internally on DC. One reason to build such equipment to operate from low-voltage AC is isolation (via a transformer) from the power line. Since only a step-down transformer is needed to provide an AC voltage that is easily rectified, filtered, and regulated, you
may be able to provide rectified, filtered, and (perhaps) regulated DC
in place of the 12 V AC input.
This would
not bypass those built-in rectification, filtering and regulation functions, or replace them. Those functions would still exist inside the medical frequency generator, but instead of providing 12V AC, 50 Hz, power input, you would simply provide a DC power input of an appropriately higher voltage, necessary to account for the forward voltage drop of internal rectifiers in the medical frequency generator.
This will not work if the medical frequency generator has a transformer inside that requires 12 V AC for its operation.
But why do you want to power your medical frequency generator from a 12 V DC power source? Is it located far from mains power (240 VAC, 50 Hz, IIRC in India)? As
@davenn stated in post #6 above, all you need is a step-down transformer (12 V AC plug pack) and access to utility power. OTOH, if AC power is unavailable and you have to operate using a car battery (or some such), you might still investigate whether the medical frequency generator will accept and operate directly from a DC source of appropriate voltage. A DC-to-DC boost converter is a lot less complicated than a 12 V AC, 50 Hz, sine-wave inverter, which you may not need.
