DC Shunt Motor
Discussion in 'Electronics Homework Help' started by vick5821, Jun 5, 2013.
  1. vick5821
    vick5821
    700
    Jan 22, 2012
  2. davenn
    davenn Moderator
    13,837
    1,952
    can you post the diagram here
    I have to register to see that link
  3. vick5821
    vick5821
    700
    Jan 22, 2012
    Here you go :)
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    The shunt winding produces a magnetic field.
    The armature is the rotating part.
    There is no difference between a motor or generator in this configuration.
    If the armature is rotated in the field, it will produce a voltage (back EMF). If this voltage is below the applied voltage, the motor takes current. If this voltage is at the applied voltage, there will be no current.
    If there is no torque and no friction (some hopes!), then the speed will rise till the two voltages match and the armature current will be zero. There will of course need to be a shunt, field current.
  5. vick5821
    vick5821
    700
    Jan 22, 2012
    If there is no armature current, how the armature develop the voltage and rotate ? Hehe
  6. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    A very good point. It will never happen because there will be friction to slow the armature down as I pointed out.
    The only thing perfect in this world is me !
  7. Merlin3189
    Merlin3189
    250
    69
    Aug 4, 2011
    Because there is a current in the field winding producing a magnetic field. A coil rotating a a magnetic field generates an emf. At the ideal free-running speed this will exactly equal the applied Voltage, so no current flows.
    Though, as has been said, this never really happens, so there will be some current to generate the torque to overcome the losses.
