Categories
Platforms
Content
There's noting much to interpret. It is Ohm's law - straightforward.would you pls interpret your formula?
..my project has 200V DC and 38000 A current..give me some advice please
Sorry, I can't follow you. From Ohm's law you get I=V/R. So where is the issue? This equation is valid regardless of the type of voltage or current, be it DC, AC or mixed.but would u please give me an example about DC calculating short cicuit?
This is for the busbar only. The cables feeding the busbar have a resistance, too, which needs to be taken into account. You need to look at the whole system, not the busbar as an isolated item.I=200/4.3x10-6 is that true?
Not when your AC values are RMS. RMS values are defined such that the AC RMS value is equivalent to the same DC value.is there any derating factor for converting Ac short circuit current to Dc?
You have been given some good advice and a reference by @Harald Kapp but you have provided no information on why you need to calculate the short-circuit current in the bus bar. You know the copper bus bars are capable of providing a 38000 ampere current to your process. They are certainly capable of more current than that, but how much short-circuit current can your power supply provide? How do you interrupt a fault current that could possibly produce a 100 kA arc?hello everyone
would u please help me,give a guidance to find DC short circuit calculation formula for copper busbar?
do u people have any idea?
