DC power supply with different V out
Discussion in 'Power Electronics' started by DavidV, Dec 5, 2017.
  1. DavidV
    DavidV
    16
    Dec 5, 2017
    I am working on a project with my high school physics students and we need to have a single battery but need to supply different voltages to different devices. I was hoping to make something that would have a 9.6V battery (rechargable NiMH 2000mAh) that can provide three levels of output 9V, 5V, and 3V. I would prefer something stable with more than just resistors in series and parallel. Maybe incorporating voltage regulators or something like that.
    Could anyone provide a relatively simple circuit diagram that would be assembled by students with basic circuit knowledge?
    David
  2. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    How muck current is required for each 9v, 5v, and 3V?
    Ken
  3. davenn
    davenn Moderator
    13,801
    1,941
    look on eBay .... there's a zillion buck regulators to choose from
  4. DavidV
    DavidV
    16
    Dec 5, 2017
    Small currents for most applications. It will be for things like IR transmitter/receiver, thermistors, photocells, LEDs. The only two items that may draw more current is a small nichrome coil heater and small electromagnet.
    Nothing will be running at the same time except trans/rec and LED/photocell pairs. So things like the electromagnet and heater will not be running at the same time and nothing will be on for more than a few seconds. The heater and thermistor will also be on together.
  5. Bluejets
    Bluejets
    4,661
    984
    Oct 5, 2014
  6. DavidV
    DavidV
    16
    Dec 5, 2017
    I didn't see many that have multiple outs. I could connect them in parallel all set at different outputs.
    Those look good but can't wait for delivery. I will dind something similar with quickly turnaround.
    Thanks.
  7. duke37
    duke37
    5,364
    770
    Jan 9, 2011
    9.6V to 9V seems too close. Would 8V do?
    Do not tap the battery or you will get some cells discharged too far and some overcharged.
    A single buck convertor could be switched for different output voltages.
  8. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Given the low current requirements and short time intervals a simple resistor/zener arrangement would do just as well as anything. Trying to keep it simple here.......
  9. davenn
    davenn Moderator
    13,801
    1,941
    no there are not
    you will have to buy 3 of them and set each one for your required voltage .... they are dirt cheap, only a few bux each
  10. Alec_t
    Alec_t
    2,940
    799
    Jul 7, 2015
    You could try this switch-selectable output regulator :-
    The P-MOSFET (M1) should preferably be a logic-level type. Rload is just a simulated load. C1 suppresses noise on the output. Almost any comparator could be used instead of the LM339 (a quad package, only a quarter of which is used here). Any unused comparator inputs should be grounded.
