I have an AC to DC power supply. From what I can tell it has two outputs. First, a high voltage (350VDC) and second a lower (12VDC) output. I'm getting about 170VDC on the high output and 0.1VDC where I'd expect the 12 volt output. The application is an older DLP projector. The high voltage output supplies a mercury lamp ballast -- with an input specification of 350VDC (that's where the assumption of what to expect on the high side came from.) The rest of the components (control panels, cooling fans, etc. seem to need 12VDC.
So, the device failed slowly -- first intermittently -- sometimes would power on, others would not, then failed completely.
I'm interested in learning to see if I can repair it myself as a learning experience since the age of the equipment doesn't justify new parts of professional repair and I just have a general interest in learning about electronics and have done some smaller (less complex) repairs/projects in the past.
So, I'm looking for ideas if anyone is knowledgeable and willing to provide suggestions. My first suspect, is what would cause some output, but not what is expected.
I posted a couple photos of the circuit also.
Thanks in advance for any helpful thoughts.
