DC power jack
Discussion in 'Electronic Design' started by terry, Nov 22, 2004.
  1. terry
    terry Guest
    I have found dc power jacks have options of 1.1mm, 1.3mm, 2.5mm, etc.
    How do I select whether I should choose which one? I prefer to use
    small one as it has small footprint. But if concerning the maximum
    current, how to choose?
    Thanks!
  2. Leon Heller
    Leon Heller Guest
    I tend to use one that matches the majority of PSs. That seems to be 2.1 mm
    for the ones with fixed connectors.
    Leon
  3. Quack
    Quack Guest
    Usually in the datasheet it will give the maximum ratings.
    Alex
  4. Choose what you like, I don't think there is any standard. 2.1mm
    is very common, but if your gadget is small, it's bit large.
    Universal adapters that come with a bunch of plugs often don't
    have the 2.5mm plug, I have noticed.
