DC plug identification help
Discussion in 'Electronic Components' started by Dan Lenski, Sep 22, 2006.
  1. Dan Lenski
    Dan Lenski Guest
    Hi all,
    I'm trying to identify what kind of AC/DC wall wart adapter I need,
    based on the female end on a speaker.
    Its measurements are as follows:
    * outside hole diameter ~5.9 mm
    * diameter of center pin receptacle ~2.7 mm
    * diameter of center pin hole ~1.1 mm
    Has anyone seen a wall wart plug with these dimensions? I can't find
    'em on digikey. Thanks for any help with it!
    Dan Lenski
  2. Eeyore
    Eeyore Guest
    The plug size is irrelevant I'm afraid. You also need to consider polarity for a
    DC supply.
    Graham
  3. Buy a universal - it'll have one that's close enough.
    _____ _ _
    |_ _| | | | |
    | | __ _ _ __ ___ | |__| | ___ _ __ ___ ___ _ __
    | | / _` | '_ ` _ \ | __ |/ _ \| '_ ` _ \ / _ \ '__|
    _| |_ | (_| | | | | | | | | | | (_) | | | | | | __/ |
    |_____| \__,_|_| |_| |_| |_| |_|\___/|_| |_| |_|\___|_|
    __ ____
    / _| | _ \
    ___ | |_ | |_) | ___ _ __ __ _
    / _ \| _| | _ < / _ \| '__/ _` |
    | (_) | | | |_) | (_) | | | (_| |_
    \___/|_| |____/ \___/|_| \__, (_)
    __/ |
    |___/
  4. Dan Lenski
    Dan Lenski Guest
    The polarity is identified on the speaker: center pin is positive,
    outer ring is ground. I thought that was standard, actually...
    Dan
