DC motor question
P
PDRUNEN
Hi Group,
Please tell me what is going on here?
1: AC 120V to full wave bridge and I read 107Vdc on the meter.
2: Connect a DC motor across the bridge (with no freewheeling diode) and I get
13000 rpm as expected but the meter reads 136V.
3: As motor is loaded, the voltage decreases and get near the 107Vdc reading.
So, in #2, where is the extra 30 Volts coming from? Can I use it to determine
motor inductance or other?
Paul
S
Spehro Pefhany
Hi Group,
You have a DC voltmeter, it reads *average* voltage.
Average voltage of full-wave rectified (unfiltered) 120VAC is about
108V, less a volt or so for the diodes.
(120 * 2* sqrt(2)/pi)
(The RMS voltage is still 120V, of course, ignoring diode losses, but
that isn't important here)
The back EMF from the motor is filling up the gaps in the waveform,
increasing the *average* voltage (the motor acts as a generator with
an voltage output of about 10mV/RPM, assuming it's a PM motor). If
there was no windage or other losses, you could expect to get as much
as 170V (sqrt(2) * 120).
The motor slows down under load and the influence of the back EMF
decreases.
Best regards,
Spehro Pefhany
