M
[email protected]
I built a pwm circuit (200 Hz switching frequency) using 12V as a supply, also using around 12V to the gate of an IRF530 mosfet. I tested it with an automotive turn signal light (about 1 amp) and it worked just fine (without a heat sink on the mosfet).
I then tried using it to control a 12V tire inflator/compressor (about 4 amps). The inflator operated fine, but then when I felt the mosfet I was surprised it was so hot it burned my finger.
Yes I know I should use a heat sink, but I've also heard I should use a protection diode. How do I size this? Won't the power be dissipated (wasted) in the diode anyway, transferring the heat from the motor to the diode?
Also, is 200 Hz the correct frequency to drive a 4A, 12V DC motor?
If I increase the frequency, won't the voltage spikes from the motor coils be even higher?
Michael
Michael
