DC MOTOR CONTROL CIRCUIT
Discussion in 'Sensors and Actuators' started by Sourabh, Jul 8, 2010.
  1. Sourabh
    Sourabh
    3
    Jun 19, 2010
    Here, S1 and S2 are normally open , push to close, press button switches. The diodes can be red or green and are there only to indicate direction. You may need to alter the TIP31 transistors depending on the motor being used. Remember, running under load draws more current. This circuit was built to operate a small motor used for opening and closing a pair of curtains. As an advantage over automatic closing and opening systems, you have control of how much, or how little light to let into a room. The four diodes surriunding the motor, are back EMF diodes. They are chosen to suit the motor. For a 12V motor drawing 1amp under load, I use 1N4001 diodes.
    [​IMG]
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Here you need to ensure that the switches can not be pressed simultaneously, or else the transistors will short out the power supply, with possible damage to either.
    Preferably use a single spdt center off switch.
Similar Threads
Loading...
