So why should I waste my and everybody else's time and band width
explaining to a moron what he should be able to see for himself.
Now he challenges what is a basic and simple battery charger anyone can
build, on the basis of it being too hard to operate.
I wouldn't call it "hard" to operate. More like "unnecessarily
inconvenient and inefficient". But as you've described its features,
it does have one that David Copperfield might be interested in:
exactly how at only 35 Amps and tapering down, it's nevertheless able
to produce over 600 Ahrs in 3 hours. That's what we might call a
six-fold magic trick. Put another way, even though 3 hour's running
would normally about cover a single day's consumption, in loaves and
fishes fashion it's apparently able to replace 6 days of discharge.
Here are 3 possible explanations:
1. That your "I know what's going on at all times" battery voltage
readings *aren't* at-rest. Instead, 12 Volts is a battery-discharging
reading, 12.8 Volts is a battery-charging reading, and neither reflect
a true state of charge. That's a common mistake made by rookies, who
usually learn to either work around the limitations or buy a proper
battery monitor. But someone claiming 20 years of experience would
have to be one hell of slow learner to keep making the same mistake.
And if we believe that's why your descriptions don't make sense, it
means that you're firing up the generator well in advance of your
frequently bragged-on 5 days autonomy being exhausted. So why "design"
for so much battery capacity if you prefer not to use it, but to run a
generator instead?
2. That the readings *are* at-rest, and represent the true state of
charge. That's the only way a knowledgeable person would quote battery
voltage without qualification. In which case the 3 hour charge routine
you described would take perhaps 21 hours. That tall of a tale makes
perfect sense considering your history of reality-optional posts.
3. That your battery capacity has deteriorated to a fraction of
nameplate. Being on your fourth set of tired batteries would explain
why you mentioned replacing the current set quite a while ago, and why
you're reluctant to talk about equalizing. With a small enough
capacity and a dollop of number fudging, your charging descriptions
could actually make some sense. But that would mean that your recent
claim of "happy" batteries is either BS or ignorance. Or most likely,
a bunch of both.
As far as my battery charger is concerned it cost me almost nothing to
build.
Reasonable readers would expect that your endlessly self-proclaimed
"design" ability wouldn't allow you to intentionally set a new
benchmark of inefficiency by marrying a 5hp engine to an oft-times
100W output. Is there any valid reason you didn't use a $5, 65A
alternator like most other people do? Or go on a mad spending spree
and buy a shiny new one for $50?
It does a better job than the $1200 electric charger that fails
so often that I have a collection of them as scrap collected from very
dissatisfied people who want one like mine.
These narrow-minded recommendations and phony choices you offer are a
reflection of your lack of experience. Why would the choice have to be
between a particular type of electric charger, and features <snorf>
such as "plugging in the field"? Why not a better-matched alternator
with said:
So, have you had time to think about it? Who's asking, you or the
pitiful long distance runner?
Daestrom asked you fairly and directly, in public, to answer "straight
forward" questions. Weasel and dissemble all you like, but it will
only prolong your time in the hot seat.
Wayne
