T
Toothpick
Hi.
This is the situation:
- the 4 DC generator's are generating from 40 - 48V of output voltage (
conected together ).
- the expected amperage would be around 60A.
Each generator is BLDC motor and the rotating speed of each one is around
400 RPM.
On this speed he can produce around 800W.
The goal is to convert this output voltage in the range between 450 - 500V
and to keep this voltage on this level, regardless on generator production.
400-500V is range needed to run motor controler but i have to have some
fixed voltage ( in this range ).
Suggestions how to make this ?
400 RPM.
