dc - ac
Discussion in 'Electronic Design' started by Josh, Mar 10, 2007.
  1. Josh
    Josh Guest
    How to convert 9.6 NiCd battery (DC)
    to 12 volt ac, or even something close to 12 volt ac.
    Thank you
  2. Day Brown
    Day Brown Guest
    How many amps?
  3. Josh
    Josh Guest
    It is 12 volts ac 2.5 amps - and i want to power it with an rc car
    battery rated at 9.6 volts dc 700 mAh, or i could use my other rc car
    battery which is 9.6 volts dc 1100 mAh.
    Thanks for responding
  4. legg
    legg Guest
    Josh,
    You are not going to find parts for this around your house.
    You should be able to find a screw driver, though. Use this to open up
    the device you are trying to power, and figure out what happens to the
    original 12V AC. You may find that there is one place in the circuit
    that will accept a DC voltage, to function normally.
    Once you know what this voltage is, you can develop a battery source
    to provide it, fairly easily.
    RL
  5. Josh
    Josh Guest
    Great - i will look into that. Thank you so much for your help.
  6. Guest
    Nothing's ever this easy. What if the device uses a half-wave
    rectifier to generate a bipolar supply from the AC?
  7. The OP doesn't have a clue. And this is really for s.e.repair anyway.
  8. Donald
    Donald Guest
    Well, lets ask the OP, Hey OP do you have/know what a volt meter is ??
  9. Josh
    Josh Guest
    Yes i do, i have one and have used it many times on many things. I
    tried opening the trans. but unfortunately the plastic casing is
    sealed - so there is no way to open it without damage.
    All i am trying to do is find a cheaper source of converting dc to ac
  10. Josh
    Josh Guest
    I just dont want to destroy something that works perfectly fine, and i
    dont feel like getting a battery in my face either. whats really
    strange is that my friend took an ac powered subwoofer and put a 9
    volt battery on it to power it. It must be such a low battery amperage
    that it doesnt cause an immediate problem - but his battery life sucks
    horrendously.
  11. Josh
    Josh Guest
    I have decided to just buy a car stereo amplifier to do this job.
    Thanks for everyones help and ideas
  12. Eeyore
    Eeyore Guest
    We need to know how many amps the amplifiers use, not the rating of the
    transformer.
    How many watts of audio do you want / need ? How long does it need to last
    before recharging ?
    Graham
  13. Forget it. Won't work.
  14. Eeyore
    Eeyore Guest
    Pretty unlikely I'd say.
    Graham
  15. Eeyore
    Eeyore Guest
    You don't need to.
    Electronics actually runs on DC.
    Graham
  16. Eeyore
    Eeyore Guest
    Does the battery life suck even when (a) the sound is quiet or (b) just when
    it's quite loud most of the time ?
    If (b) you're not going to be able to fix that.
    Graham
  17. I have a toy that runs off 4 C cells or a 4 VAC adaptor - it clearly has a
    split supply.
  18. Guest
    Maybe. Either way it's not a half-wave rectifier I meant, it's a
    voltage doubler, but anyways...
    I don't see why it's that unlikely. It's a great way to generate a
    bipolar supply.
  19. jasen
    jasen Guest
    For audio?
    with a 2.5A input it's maximum 30W dissipation, so probably under 15W output,
    12V DC is plenty for that.
  20. jasen
    jasen Guest
    only if you don't mine the ripple.
    Bye.
    Jasen
