E
eeh
Could anyone tell me how to calculate 20W in dbm? Is it equal to
10log(20/0.001)?
Thanks!
10log(20/0.001)?
Thanks!
eeh said:Hi,
10log(20/0.001)?
Pooh said:eeh wrote:
Yup.
Ted said:Shouldn't that be 10*10log(20/0.001)?
Ted
eeh said:Hi,
10log(20/0.001)?
Walter said:Although the answers you've gotten are fine, this seems like kind of
an odd question to be asking in the first place. The sort of systems
(line-level audio) that are specified in dBm don't usually involve
power levels anywhere near 20W.
What he said....we care always using dbm and dbW in satellite comm's.Paul said:It's quite common in RF technology also, and 20W is not exactly super
power...
Paul
Although the answers you've gotten are fine, this seems like kind of an odd
question to be asking in the first place. The sort of systems (line-level
audio) that are specified in dBm don't usually involve power levels anywhere
near 20W. Indeed, dBm is kind of an obsolete measurement, even for audio;
Walter said:Although the answers you've gotten are fine, this seems like kind of an odd
more commonly these days, we see dBu, which is essentially a voltage
measurement rather than a power measurement. (0dBu = 0.7748V, which happens
to be the voltage that would produce 1mW into a 600 ohm load.)
Are you sure you're asking the right question? What is the context?
Dave said:[...]
In "low power" RF engineering, dBm is *much* more commonly used to
indicate power than any other unit [...]
More like 10*log10(20/0.001) if you like but since ln is normally used
for natural logs then log without a suffix may be reasonably taken to
mean base10.
