DB9
rahila
May 26, 2012
11
May 26, 2012
11
i want db9 female to db9 male connection diagram with color codes
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Connect
1----1
2----2
3----3
4----4
5----5
6----6
7----7
8----8
and
9----9
And use whatever colour you want.
Or do you need to do something "interesting" with the cable? Is it an RS-232 "null modem" cable you're after? Or a VGA cable? Or something else? I'm not sure what DB9's are used for any more...
GreenGiant
Feb 9, 2012
842
Feb 9, 2012
842
since youre just creating a jumper color codes don't matter that much, just make sure that the colors match up for each end (green pin 1 to pin 1 on the other side)
but if you want to do it "correctly" try this
